Solved DDNS Connection
fotingo
I notice every time my ISP modem reboots for any reason, the DDNS on my Asus router becomes "inactive".
Even if I click on Apply again at the bottom of the screen, it won't connect. I've tried disabling and re-enabling the service, still does not connect.
But, if I enter a new Host Name and register it, then it becomes active.
At that point I can enter my regular Host Name and hit Apply, and it stays active.
Is this a normal behavior, or do I need to make a change on a setting for the service to reconnect after the Internet is back?
Thank you.
I have been looking and found Dynu which provides free ddns server. I set up an account with them and was able to get "Registration Successful" on the router after entering my login from Dynu.
But, I realized I used Dyndns.org as I thought it was Dynu.
My question is, if Dynu and Dyndns are not the same company, how come I was able to use the same credentials and get a successful registration?
I also used the same credentials with namecheap.com and also got a "Registration Successful".
Is this normal?
How come I am able to use the same credentials for dynu, dyndns and namecheap?
I use afraid.org in the drop-down, works great
I've read that you have to check-in every 6 months or so if not the account deactivates. Knowing me, I may forget to do that. Looking for something I can just setup and forget about it like the one from Asus. The issue is I now have an ISP modem that does not have bridge mode option, so I am behind NAT and now every time the modem reboots, the DDNS service will not reconnect automatically and becomes inactive.
When I had the bridge mode option, this wasn't an issue. I'm thinking that maybe it will be the same with any DDNS server I use due to the double nat issue.
Is there a way to make the DDNS server reconnect automatically when behind NAT?
I posted the steps for you in another thread. I have not had a need for it in a while but I just set it up again to test and my dynu domain works.
Which thread? I can't find it. Can you share the the link to it?
That's where I went, but I don't see your instructions there. The last post I see is mine asking you how you did this.
It has been a while since I was using it.
To use Dynu.net through DNSomatic, you need to set up a DNSomatic "Dynamic DNS" record pointing to your Dynu domain name; essentially, you'll configure DNSomatic to update your Dynu hostname with your current IP address whenever it changes, allowing you to access your network using the Dynu domain even with a dynamic IP address.
Here's how to do it:
  • Create a Dynu account: If you don't have one already, sign up for a Dynu account and create a desired hostname (e.g., "myhome.dynu.com").
  • Access DNSomatic: Log in to your DNSomatic control panel.
  • Add a new DNS record: Navigate to the section for managing DNS records and choose the "Dynamic DNS" record type.
  • Configure details: [
    • Hostname: Enter the Dynu domain name you created (e.g., "myhome.dynu.com").
    • Provider: Select "Dynu" from the list of available providers.
    • Username and Password: Input your Dynu login credentials.
  • Update interval: Set how often DNSomatic should check for IP changes and update the Dynu record (usually a few minutes).
  • Activate the record: Save your settings and enable the newly created Dynamic DNS record.
Important points to remember:
  • Router configuration: You might need to configure your router to use the Dynu hostname and update its IP address automatically through the Dynu service, depending on your router model.
  • Testing: After setting up the DNSomatic record, test if it's working by accessing your network using the Dynu domain name from another device on the internet.
The issue has been solved. My ISP was able to provide a stand alone ONT modem and that fixed the DDNS issue not automatically connecting.
