What is the frontend gui for the router on Pi (Arm)? That is the problem I had plus I wanted more ethernet ports then 1, and a usb wifi. Like mentioned you will never saturate the 100Mb connection, I guess if your good at iptables or install openvpn (openvpn connect has a web gui) to it. There are low powered Intel devices out there with multiple nics that you can slap on *sense etc. I really like bsd now.
I'm a bit confused. When you're talking about 'VPN Routers' are you referring to business ipsec vpn routers, or those designed to connect to a vpn service? They're distinctly two different types of devices.Many of the "VPN routers" do their own flavor of VPN...
SEM makes a good point - interoperability is a good thing, and many of the "VPN routers" may not have this, rather, they stay in their private garden..
both. While VPN routers offer both client and server (both are used in tunneling situations), consumer routers can also offer the same too but not all routers include the vpn server in their firmware. However unlike VPN routers the firmware used for consumer routers nowaday is just a normal linux with some software running on it. Its not a fully equipped linux like a desktop but its the same linux kernel compiled for the CPU architecture with drivers and software. So theres no reason why you cant install your own VPN server especially when you can use openwrt on them which makes them way better too, giving you the full features and control over the vpn featureset and network if you want. Sure the VPN routers have GUI whereas for the consumer routers that dont you have to resort to CLI but the consumer ones will run vpn better as they have the same underlaying software and a faster CPU.I'm a bit confused. When you're talking about 'VPN Routers' are you referring to business ipsec vpn routers, or those designed to connect to a vpn service? They're distinctly two different types of devices.
I've never seen a consumer router that can do ipsec site-to-site tunnels to connect to other business/enterprise vpn routers.both. While VPN routers offer both client and server (both are used in tunneling situations), consumer routers can also offer the same too but not all routers include the vpn server in their firmware. However unlike VPN routers the firmware used for consumer routers nowaday is just a normal linux with some software running on it. Its not a fully equipped linux like a desktop but its the same linux kernel compiled for the CPU architecture with drivers and software. So theres no reason why you cant install your own VPN server especially when you can use openwrt on them which makes them way better too, giving you the full features and control over the vpn featureset and network if you want. Sure the VPN routers have GUI whereas for the consumer routers that dont you have to resort to CLI but the consumer ones will run vpn better as they have the same underlaying software and a faster CPU.
http://demoui.asus.com/Advanced_VPNClient_Content.aspI've never seen a consumer router that can do ipsec site-to-site tunnels to connect to other business/enterprise vpn routers.
I know all this, but what you cannot do is setup a tunnel to another ipsec site-to-site vpn router--which is the standard for site-to-site vpn tunnels.http://demoui.asus.com/Advanced_VPNClient_Content.asp
stock asus wrt firmware, you can have openvpn and pptp vpn server, you can connect to other vpn servers that do pptp, l2tp and openvpn. All a tunnel is is just 1 router being client, 1 being server. l2tp would require ipsec.
Another option is to order a J1900 Qotom from China. No Fan, handles heat (65C at idle during noon), Go with opnsense as it supports dnscrypt and openvpn XOR scramble patch with little effort. Does not have AES instructions, but I have not noticed any extra lag besides ping related to distance of server.
I agree, and the problem of even owning both ends of the link is that the link is still managed/monitored by the isp on that end.Personally, I'm not a big fan of the commercial VPN services - it's mostly an issue of trust, and if one doesn't own both ends of a VPN link, there is no trust, no matter what they say or promise...
There will never be any way to get on a network as vast as the Internet without having exposure. It's just like going out into the real world--there's bad people there too that you have to avoid. Welcome to the worst of the world, virtual style.
| Thread starter | Title | Forum | Replies | Date |
| U | Wired router recommendation | Routers | 5 | |
| F | Router for a VPN with WiFi 7 | Routers | 6 |
Welcome To SNBForums
