Defect Report : USB HDD not detected correctly by the USB driver
algorab
I think I found a defect pertaining to the USB driver. I do not know if it is specific to asuswrt or asuswrt-merlin, because from day one, I loaded Merlin's firmware.
What happens is that on boot, with the HDD connected, the OS reports that it had detected sda or sdb, but it does not detect the partitions, sda1, sda2, ... or sdb1, sdb2, ... Thus, the drive's partitions cannot be auto mounted.
After this happens, if I remove the drive from the USB port and reattach it, the devices are detected correctly and are auto mounted.
Im having similar problems with the last 2 merlin builds.
USB drive does no mount, if it does usb drive corrupted according to the router.
Clicking on the gui to renew status of drive crashes the router.
Now, this only happens with Usb stick regardless of the usb port.
My samsung 1TB drive has no such problems.
The only way i managed to have the usb sticks working was removing any name labels on it.
I have so far reseted the router 3 times.
Here is some of the logs, Maybe someone can shed some light.
usb_dbg: asus_usb_interface] (1-1): action=add.
[usb_dbg: asus_usb_interface] (1-1): Fail to get usb node.
[usb_dbg: asus_usb_interface] (1-1:1.0): action=add.
[usb_dbg: asus_usb_interface] (1-1:1.0): Fail to get usb node.
[usb_dbg: asus_usb_interface] (1-1.1): action=add.
[usb_dbg: asus_usb_interface] (1-1.1): Fail to get usb node.
[usb_dbg: asus_usb_interface] (1-1.1:1.0): action=add.
[usb_dbg: asus_usb_interface] (1-1.1:1.0): Not modem interface.
[usb_dbg: asus_usb_interface] (1-1.2:1.0): action=add.
[usb_dbg: asus_usb_interface] (1-1.2:1.0): Not modem interface.
[usb_dbg: asus_usb_interface] (1-1.2): action=add.
[usb_dbg: asus_usb_interface] (1-1.2): Fail to get usb node.
[usb_dbg: asus_sd] (sda5): action=add.
[usb_dbg: get_usb_node_by_device] (lp0): Fail to get link: /sys/class/usb/lp0/device.
[usb_dbg: get_usb_node_by_device] (lp1): Fail to get link: /sys/class/usb/lp1/device.
[usb_dbg: get_usb_node_by_device] (lp2): Fail to get link: /sys/class/usb/lp2/device.
[usb_dbg: get_usb_node_by_device] (lp3): Fail to get link: /sys/class/usb/lp3/device.
[usb_dbg: get_usb_node_by_device] (lp4): Fail to get link: /sys/class/usb/lp4/device.
[usb_dbg: get_usb_node_by_device] (lp5): Fail to get link: /sys/class/usb/lp5/device.
[usb_dbg: get_usb_node_by_device] (lp6): Fail to get link: /sys/class/usb/lp6/device.
[usb_dbg: get_usb_node_by_device] (lp7): Fail to get link: /sys/class/usb/lp7/device.
[usb_dbg: get_usb_node_by_device] (lp8): Fail to get link: /sys/class/usb/lp8/device.
[usb_dbg: get_usb_node_by_device] (lp9): Fail to get link: /sys/class/usb/lp9/device.
[usb_dbg: asus_sd] (sda): action=add.
[usb_dbg: asus_sd] (sda): Success!
[usb_dbg: asus_sg] (sg0): action=add.
[usb_dbg: init_3g_param] 3G: Auto setting.
[usb_dbg: asus_sg] (sg0): insmod cdrom!
[usb_dbg: asus_sd] (sda1): action=add.
[usb_dbg: asus_sg] (sg0): Success!
[usb_dbg: asus_sd] (sdb): action=add.
[usb_dbg: asus_sd] (sdb1): action=add.
[usb_dbg: asus_sg] (sg1): action=add.
[usb_dbg: asus_sg] (sg1): insmod cdrom!
[usb_dbg: asus_sg] (sg1): Success!
[usb_dbg: main] samba mode: share
[usb_dbg: asus_sd] (sdb): Success!
[usb_dbg: asus_sd] (sda5): Success!
[usb_dbg: asus_sd] (sdb1): Success!
[usb_dbg: asus_sd] (sda1): Success!][/CODE]
