Devices associated but not completing connection
ah1750
Looking for some help here after some exhaustive research on the issue. I'm running Merlin on a RT-AX86U, 3004.388.7 (which is one step back from the latest firmware). It's remote so I don't have access to it or the devices right now. The devices are two different Tuya-based iot devices. One is about 1 meter from the router, the other is much further away. Both are having the same issue where they are constantly associating with the router and then disassociating, and never fully connecting.
I've read several times the "sending station is leaving" is a normal log entry, however since these devices are never connected I'm trying to sort out how to remotely "reset" their connection or do something to get them connected. I'm accessing the router via the Asus App via "security link," and I also have SSH access to it via a VPN. If there's a command line method of resetting the connection or something, I'd love to hear it.
What I've tried: rebooting (many times), changing the various wifi settings -- right now the system is set to only 2.4 Auto (tried legacy, N only, etc), fixed channel, 20MHz, b/g protection is on. Professional settings are dumbed down to have roaming assistant off, beam forming, airtime fairness etc. switched off as well. I've also tried blocking their internet, binding to the AP, DHCP reservations, etc.
In the Asus remote app you can see the devices' connection strength changing, but they are marked as offline.
Thanks in advance for any ideas.
Sep 5 08:21:23 hostapd: eth6: STA a8:80:55:6d:59:c7 IEEE 802.11: disassociated
Sep 5 08:21:23 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind A8:80:55:6D:59:C7, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 5 08:21:24 wlceventd: wlceventd_proc_event(685): eth6: Auth A8:80:55:6D:59:C7, status: Successful (0), rssi:0
Sep 5 08:21:24 hostapd: eth6: STA a8:80:55:6d:59:c7 IEEE 802.11: associated
Sep 5 08:21:24 wlceventd: wlceventd_proc_event(722): eth6: Assoc A8:80:55:6D:59:C7, status: Successful (0), rssi:-66
Sep 5 08:21:24 hostapd: eth6: STA a8:80:55:6d:59:c7 RADIUS: starting accounting session 4D49024C0A0A1630
Sep 5 08:21:24 hostapd: eth6: STA a8:80:55:6d:59:c7 WPA: pairwise key handshake completed (RSN)
Sep 5 08:22:14 kernel: wl0: random key value: 3625AA8FE6440FC4564F0083BE90D8461DF50D4041DC02D3C1CF2F4D8A8B59A4
Sep 5 08:22:14 hostapd: eth6: STA a8:80:55:cd:86:27 IEEE 802.11: disassociated
Sep 5 08:22:14 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind A8:80:55:CD:86:27, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 5 08:22:14 dnsmasq-dhcp[8108]: DHCPREQUEST(br0) 192.168.51.162 d8:d6:68:bc:eb:97
Sep 5 08:22:14 dnsmasq-dhcp[8108]: DHCPACK(br0) 192.168.51.162 d8:d6:68:bc:eb:97 lwip0
Sep 5 08:22:15 wlceventd: wlceventd_proc_event(685): eth6: Auth A8:80:55:CD:86:27, status: Successful (0), rssi:0
Sep 5 08:22:15 hostapd: eth6: STA a8:80:55:cd:86:27 IEEE 802.11: associated
Sep 5 08:22:15 wlceventd: wlceventd_proc_event(722): eth6: Assoc A8:80:55:CD:86:27, status: Successful (0), rssi:-53
Sep 5 08:22:15 hostapd: eth6: STA a8:80:55:cd:86:27 RADIUS: starting accounting session E7256294C7552147
Sep 5 08:22:15 hostapd: eth6: STA a8:80:55:cd:86:27 WPA: pairwise key handshake completed (RSN)
Sep 5 08:22:23 kernel: wl0: random key value: DFE13ABFD7179402516E0151A5E2D7E8A382B889ABC609312D085A30B746FC17
Sep 5 08:22:23 hostapd: eth6: STA a8:80:55:6d:59:c7 IEEE 802.11: disassociated
Sep 5 08:22:23 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind A8:80:55:6D:59:C7, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 5 08:22:24 wlceventd: wlceventd_proc_event(685): eth6: Auth A8:80:55:6D:59:C7, status: Successful (0), rssi:0
Sep 5 08:22:24 hostapd: eth6: STA a8:80:55:6d:59:c7 IEEE 802.11: associated
Sep 5 08:22:24 wlceventd: wlceventd_proc_event(722): eth6: Assoc A8:80:55:6D:59:C7, status: Successful (0), rssi:-67
Sep 5 08:22:24 hostapd: eth6: STA a8:80:55:6d:59:c7 RADIUS: starting accounting session 5200EAC8D211CCA4
Sep 5 08:22:24 hostapd: eth6: STA a8:80:55:6d:59:c7 WPA: pairwise key handshake completed (RSN)
Sep 5 08:23:14 kernel: wl0: random key value: 4730F216F23C76AE37900138FDC340582DC4AAC7E4CC0B44BC7CB627546692BC
Sep 5 08:23:14 hostapd: eth6: STA a8:80:55:cd:86:27 IEEE 802.11: disassociated
Sep 5 08:23:14 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind A8:80:55:CD:86:27, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 5 08:23:16 wlceventd: wlceventd_proc_event(685): eth6: Auth A8:80:55:CD:86:27, status: Successful (0), rssi:0
Sep 5 08:23:16 hostapd: eth6: STA a8:80:55:cd:86:27 IEEE 802.11: associated
Sep 5 08:23:16 wlceventd: wlceventd_proc_event(722): eth6: Assoc A8:80:55:CD:86:27, status: Successful (0), rssi:-52
Sep 5 08:23:16 hostapd: eth6: STA a8:80:55:cd:86:27 RADIUS: starting accounting session 68A5BFCF5F61C38D
Sep 5 08:23:16 hostapd: eth6: STA a8:80:55:cd:86:27 WPA: pairwise key handshake completed (RSN)
Sep 5 08:23:23 kernel: wl0: random key value: BEA6AE4EFF399B797AF4021D991CC04D7F971531B9A700866E286830D8E71E6B
Sep 5 08:23:23 hostapd: eth6: STA a8:80:55:6d:59:c7 IEEE 802.11: disassociated
Sep 5 08:23:23 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind A8:80:55:6D:59:C7, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 5 08:23:24 wlceventd: wlceventd_proc_event(685): eth6: Auth A8:80:55:6D:59:C7, status: Successful (0), rssi:0
Sep 5 08:23:24 hostapd: eth6: STA a8:80:55:6d:59:c7 IEEE 802.11: associated
Sep 5 08:23:24 wlceventd: wlceventd_proc_event(722): eth6: Assoc A8:80:55:6D:59:C7, status: Successful (0), rssi:-67
Sep 5 08:23:24 hostapd: eth6: STA a8:80:55:6d:59:c7 RADIUS: starting accounting session 5DA1326AF5C197FB
Sep 5 08:23:24 hostapd: eth6: STA a8:80:55:6d:59:c7 WPA: pairwise key handshake completed (RSN)
