Just wondering if this is reasonably simple to do? I'm currently running dnsmasq to point specific domains over specific DNS IP's. Everything else goes over another DNS IP address set at the WAN configuration level.
Is it possible to have a VPN client up and running and point all DNS traffic only towards the VPN?
Better still, could you point some DNS lookups to one VPN client and others to another VPN client while having everything else go through the main WAN DNS IP's?
You could probably do something with a script, to set a mark on any outbound port 53 traffic in the nat table of iptables, on the prerouting chain. Then have an ip rule that sends anything matching that mark to lookup in the vpn client routing table.
I'll try to cobble together an example when I get home, but a more VPN and routing-versed member such as @Martineau may have a script or snippet already available to demonstrate it!
When 'Accept DNS Configuration=Exclusive' is set, the firmware creates a DNS lookup table for the appropriate VPN Client:
e.g. ALL router DNS lookup requests pass through all active VPN Clients...
iptables --line -t nat -nvL DNSVPN1 2>/dev/null;iptables --line -t nat -nvL DNSVPN2 2>/dev/null
Chain DNSVPN1 (2 references)
num pkts bytes target prot opt in out source destination
1 0 0 DNAT all -- * * 172.16.1.1 0.0.0.0/0 to:104.223.91.194
2 0 0 DNAT all -- br1 * 10.88.101.0/24 0.0.0.0/0 to:104.223.91.194
Chain DNSVPN2 (2 references)
1 0 0 DNAT all -- * * 172.16.2.1 0.0.0.0/0 to:208.67.222.222
2 0 0 DNAT all -- br2 * 10.88.102.0/24 0.0.0.0/0 to:208.67.222.222
If a dnsmasq 'server=/domain.com/xxx.xxx.xxx.xxx' entry is to always use the specific/private regional DNS provided by the VPN ISP then I do have a script
Not sure if this is what you require? or do you wish to have all DNS lookups for domain xyz.com using say 8.8.8.8 to be resolved by Google explicitly via one of the VPN tunnels to prevent DNS leaks?
@Martineau Along the same lines, I only want to route pandora.com to the VPN DNS.
In the dnsmasq.conf.add i have added server=/pandora.com/209.222.18.222 (DNS for VPN), however it is still not routing using "US" location. What am I missing?
Whilst the VPN DNS (209.222.18.222) may resolve 'pandora.com'; the actual traffic will need a specific rule i.e. RPDB or fwmark for the IP returned to access the "US" location.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
