Thanks for your response.If this extender is in wireless AiMesh configuration - it appears WPS is used by AiMesh for restoring lost connection to nodes. I did some experiments in the past with WPS disabled on the main router after setting up wireless AiMesh - failed nodes never re-connected. Make sure you really want to disable WPS before poking node's settings in SSH.
My real question is if WPS is enabled on an AiMesh node but not on my main router, can someone exploit it?Not sure if this makes a big difference because AiMesh by design can fail back to wireless backhaul when the Ethernet connection is lost for whatever reason. One possible workaround is selecting Ethernet backhaul in AiMesh settings, but folks found by trial and error it's not always better than Auto. Experiment and see what happens, but try not to disturb AiMesh too much. It's closed source, Asus is making constant changes, there is total AiMesh redesign going on... you don't know what will break.
I don't think I have a device that can connect via WPS.Can you actually connect a device to your network using WPS or just some software scanner is showing it enabled?
Welcome To SNBForums
