TheMegaMan
I raised a thread a week or so about problems I was having with my RT-AC86U, regarding really slow DNS responses, and also Fing complaining that DHCP wasn't always happy.
@L&LD suggested I do a full wipe and reset, which I reluctantly did. The good news is that this seemed to solve the problems I was having. DNS is now quick again, so I'm not getting any timeout errors, and I've not seen Fing complain about DHCP, either.
The bad news is that, having been working nicely now for a week, I'm now getting really erratic performance on 2.4GHz. It's not dying completely (as other threads on here have reported), but it keeps slowing down to unacceptable levels. The speed test built into the router is reporting >70Mbps, and connecting to the router on 5GHz is giving speeds very similar to that from my PC. Real world downloads seem to back this up.
However, when connecting on the 2.4GHz band (and I have some machines that don't support 5GHz, so I need to use 2.4GHz sometimes), I'm sometimes seeing results <1Mbps. The best I've seen is 30Mbps, and it seems to vary within this range, over a period of 15 minutes or so, for no reason I can identify. I can't even stream YouTube at a resolution that allows me to read banner text.
I've selected fixed channel 11, 20MHz bandwidth only, and Roaming Assistant and Smart Connect are off. I've also disabled TX bursting and Universal Beamforming (as recommended elsewhere), but I think all other settings are still default. None of these settings were changed in the week following the hard reset and the 2.4GHz performance getting unusable. It was initially OK.
I really hope the advice isn't 'hard reset it again'...I've not make any firmware updates since last time, and needing to reconfigure it every week isn't workable.
So what other routers are comparable with the RT-AC86U (supporting 50+ devices at a time, VPN server, etc)? Netgear? TP-Link? I don't think I need AX yet, but if there's a killer alternative to the AC86U that's AX, then I could be persuaded to get one. I do wonder whether I should have got the RT-AX86U, but if all current Asus routers are as flaky as this one seems to be, I had a lucky escape from wasting even more money.
I'm on the verge of dropping the Asus in the bin, and jumping to a different manufacturer. A real shame, as I do like the flexibility of Merlin and my old RT-AC68U ran for years without any problems, until it started suffering with the heat. A shame, but the RT-AC86U has not been a good user experience so far.
