Diversion Diversion 5.1.3 - the Router Ad-Blocker, May 09, 2024
I used to come to Detroit a lot when I was working for another Company. There used to be plenty of car plants that used the systems we built.
With my now employer the closest system to you is over in Grand Rapids. I have never seen so many rusted out and see-through cars as in that area.
I'll be vacationing in the southwestern deserts if you look for me. As I always do.
I’m sure I’ll just be one of many wishing you a lovely vacation and asking if you’ll post us the odd photo, as you did a few years back. Five, six years, was it?
I'll make it memorable.
Good news at the Dnsmasq v2.90 front for Diversion users: There is light at the horizon - I tested what I could and the fix appears to work.
I need to do some more testing with pre-2.90 Dnsmasq versions, they don't quite behave as they should with the fix. I may have to build in a switch that applies old and new Dnsmasq versions. But first: 💤🛏️😴
Visions of Dnsmasq in his dreams...
Dave an I sitting in an English pub, chatting with Simon Kelley about the old days. All gray haired and with beards.
I‘m having a pint of Guiness.
Only one pint?!?
Diversion 5.1.1 is now available
What's new in this patch release
- Fixes failed Dnsmasq version 2.90 start up when option(s) b, 5 to 7 are used. Thanks @dave14305 for pointing me in the right direction.
- Corrects wrong EHLO (Extended Hello) string when mailing an attachment with curl. Thanks GitHub user tazio for reporting.
- Fixes a couple of edit list el problems.
Awesome! Thanks for the super quick fix. Just re-installed 388.6.2 and all seems to be working fine again.
Updated Diversion to 5.1.1 and enabled "exclude devices from ad-blocking" and Dnsmasq restarted without failure on AC-1900P using 386.12_6. Great work. Thanks.
I am confused too...
Start from scratch by:
1. Remove Device in DNS Director Client list. Make sure it can again connect to the web.
- done and works
2. In Diversion enter 1233 and confirm to do so, I uploaded a small change that also removes the resolver file when removing.
- could not find 1223 (options are alphabet) but did force an update
3. Remove the feature in b, 5
- done
4. Remove blocking list fast switch feature in b, 1, 3
- done
Then Start new:
1. Enable blocking list fast switch feature in b, 1, 3
- done
2. Enable the alternate blocking list in b, 5, enter the reserved IP address
- done
3. In DNS Director add reserved IP to User defined DNS 1
- done
4. Add device to the Client list and set User defined DNS 1, click Apply
- device was already in manually assigned client list, but had had missed modifying the DNS
5. Test if device has internet access and follow the log file for the alternate blocking list.
- all good
6. If all goes well, add google DNS to b, 5, 4
- jumped to 8
7. Test if device still has access, if so
8. Change google to cloudfare 1.1.1.1 server and if it works now, add the IPv6 IP 2606:4700:4700::1111 as well.
HUGE MISTAKE!!!
Got too keen, missed out 6 - jumped to 8, for about a minute all seemed good, then when browsing to a new site on .118 lost all connectivity to the router from all devices - the last message in the SSH window
The Router ignored all attempts at soft and hard reboots - eventually had to do a factory reset and then reloaded a backup from Sunday - thank you @Viktor Jaep for Backupmon - before I started adding the alternate list settings - and 3hr 40mins later - everything is finally back up. I will leave trying again until the weekend and when everyone else is out or at least not connected.
Updated to 5.1.1, added alternate block list, assigned the device and all is well. Many thanks . Archiel
I just updated to Diversion 5.1.1 also and re-enabled "exclude devices from ad-blocking" on AX88U 388.6.2. Working great!!
Many thanks
This might be another problem unrelated to Diversion.
A vanilla Diversion installation does not have a problem with Dnsmasq v2.9x.
Only if you use options b, 5|6|7. They start a separate Dnsmasq instance and that throws the error.
It has crossed my mind but today I found that it wad something to do with it.
problem solved , completely uninstall diversion, reboot the GT-60000, install 3004.388.6_2, reinstall latest version of diversion 5.1.1 that was released this morning.
everything looks good so far
Successful upgrade to Diversion 5.1.1 - thank you @thelonelycoder
I tested Diversion on this website and it showed 66% of ads blocked. Is it more or less correct? Thank you!
https://d3ward.github.io/toolz/adblock
script_ads : false
script_pagead : false
Amazon => n° tests => 5
Google Ads => n° tests => 4
Doubleclick.net => n° tests => 5
Adcolony => n° tests => 4
Media.net => n° tests => 3
Ads => Total n° tests => 21
Google Analytics => n° tests => 4
Hotjar => n° tests => 7
MouseFlow => n° tests => 7
FreshWorks => n° tests => 3
Luckyorange => n° tests => 8
Stats WP Plugin => n° tests => 1
Analytics => Total n° tests => 30
Bugsnag => n° tests => 4
Sentry => n° tests => 2
Error Trackers => Total n° tests => 6
Facebook => n° tests => 2
Twitter => n° tests => 2
LinkedIn => n° tests => 2
Pinterest => n° tests => 5
Reddit => n° tests => 2
YouTube => n° tests => 1
TikTok => n° tests => 7
Social Trackers => Total n° tests => 21
Yahoo => n° tests => 11
Yandex => n° tests => 7
Unity => n° tests => 4
Mix => Total n° tests => 22
Realme => n° tests => 4
Xiaomi => n° tests => 7
Oppo => n° tests => 4
Huawei => n° tests => 6
OnePlus => n° tests => 2
Samsung => n° tests => 5
Apple => n° tests => 8
OEMs => Total n° tests => 36
cosmetic_static_ad : false
cosmetic_dynamic_ad : false
adtago.s3.amazonaws.com - blocked
advice-ads.s3.amazonaws.com - blocked
pagead2.googleadservices.com - blocked
afs.googlesyndication.com - blocked
stats.g.doubleclick.net - blocked
ad.doubleclick.net - blocked
m.doubleclick.net - blocked
mediavisor.doubleclick.net - blocked
adc3-launch.adcolony.com - blocked
ads30.adcolony.com - blocked
events3alt.adcolony.com - blocked
static.doubleclick.net - blocked
wd.adcolony.com - blocked
static.media.net - blocked
adservice.google.com - not blocked
media.net - blocked
adservetx.media.net - blocked
analytics.google.com - blocked
click.googleanalytics.com - blocked
google-analytics.com - blocked
ssl.google-analytics.com - blocked
adm.hotjar.com - blocked
script.hotjar.com - blocked
insights.hotjar.com - blocked
identify.hotjar.com - blocked
careers.hotjar.com - blocked
surveys.hotjar.com - blocked
mouseflow.com - blocked
o2.mouseflow.com - blocked
cdn.mouseflow.com - blocked
api.mouseflow.com - blocked
gtm.mouseflow.com - blocked
tools.mouseflow.com - blocked
cdn-test.mouseflow.com - blocked
events.reddit.com - not blocked
api.luckyorange.com - blocked
realtime.luckyorange.com - blocked
cdn.luckyorange.com - blocked
w1.luckyorange.com - blocked
upload.luckyorange.net - blocked
stats.wp.com - blocked
cs.luckyorange.net - blocked
settings.luckyorange.net - blocked
sessions.bugsnag.com - blocked
notify.bugsnag.com - blocked
ads.pinterest.com - blocked
analytics.pointdrive.linkedin.com - blocked
ads.linkedin.com - blocked
an.facebook.com - blocked
static.ads-twitter.com - blocked
ads-api.twitter.com - blocked
pixel.facebook.com - blocked
trk.pinterest.com - blocked
log.pinterest.com - blocked
analytics.pinterest.com - blocked
events.redditmedia.com - blocked
ads.youtube.com - blocked
analytics.tiktok.com - blocked
analytics.yahoo.com - blocked
ads.yahoo.com - blocked
ads.tiktok.com - blocked
geo.yahoo.com - blocked
analytics.query.yahoo.com - blocked
partnerads.ysm.yahoo.com - blocked
advertising.yahoo.com - blocked
gemini.yahoo.com - blocked
log.fc.yahoo.com - blocked
appmetrica.yandex.ru - blocked
advertising.yandex.ru - blocked
webview.unityads.unity3d.com - blocked
auction.unityads.unity3d.com - blocked
adserver.unityads.unity3d.com - blocked
config.unityads.unity3d.com - blocked
iot-eu-logser.realme.com - blocked
iot-logser.realme.com - blocked
data.mistat.xiaomi.com - blocked
api.ad.xiaomi.com - blocked
sdkconfig.ad.xiaomi.com - blocked
sdkconfig.ad.intl.xiaomi.com - blocked
tracking.rus.miui.com - blocked
adsfs.oppomobile.com - blocked
adx.ads.oppomobile.com - blocked
data.ads.oppomobile.com - blocked
samsungads.com - blocked
nmetrics.samsung.com - blocked
iadsdk.apple.com - blocked
smetrics.samsung.com - blocked
open.oneplus.net - blocked
samsung-com.112.2o7.net - blocked
metrics.icloud.com - blocked
metrics.mzstatic.com - blocked
weather-analytics-events.apple.com - blocked
notes-analytics-events.apple.com - blocked
analyticsengine.s3.amazonaws.com - not blocked
pagead2.googlesyndication.com - not blocked
udc.yahoo.com - not blocked
analytics.s3.amazonaws.com - not blocked
udcm.yahoo.com - not blocked
events.hotjar.io - not blocked
advertising-api-eu.amazon.com - not blocked
metrics2.data.hicloud.com - not blocked
grs.hicloud.com - not blocked
logbak.hicloud.com - not blocked
claritybt.freshmarketer.com - not blocked
extmaps-api.yandex.net - not blocked
adfstat.yandex.ru - not blocked
offerwall.yandex.net - not blocked
logservice1.hicloud.com - not blocked
business-api.tiktok.com - not blocked
logservice.hicloud.com - not blocked
ads-api.tiktok.com - not blocked
adfox.yandex.ru - not blocked
metrics.data.hicloud.com - not blocked
analytics-sg.tiktok.com - not blocked
ads-sg.tiktok.com - not blocked
metrika.yandex.ru - not blocked
ck.ads.oppomobile.com - not blocked
api.bugsnag.com - not blocked
app.bugsnag.com - not blocked
browser.sentry-cdn.com - not blocked
log.byteoversea.com - not blocked
books-analytics-events.apple.com - not blocked
widgets.pinterest.com - not blocked
app.getsentry.com - not blocked
bdapi-ads.realmemobile.com - not blocked
fwtracks.freshmarketer.com - not blocked
api-adservices.apple.com - not blocked
click.oneplus.cn - not blocked
advertising.apple.com - not blocked
adtech.yahooinc.com - not blocked
bdapi-in-ads.realmemobile.com - not blocked
analytics-api.samsunghealthcn.com - not blocked
data.mistat.india.xiaomi.com - not blocked
data.mistat.rus.xiaomi.com - not blocked
Total : 140
Blocked : 92
Not Blocked : 48
script_ads : false
media.net - blocked
Total : 140
Blocked : 92
Not Blocked : 48
It’s not diversion, what Adblock lists are you using vs what is that site checking against
