Diversion Diversion 5.4.6 - the Router Ad-Blocker, July 27, 2025
thelonelycoder
Part of the Furniture
Diversion 5.4.6 is now available
  • Some cosmetic changes here and there.
  • Fixes grep error output when a uiDivStats installation is incomplete. Thanks to @fritzk33 for reporting.
  • Adds garycnew.github.io to the shared-Diversion-whitelist.
@thelonelycoder: You've been busy lately! Thanks for the continued support.
And so have many other devs by releasing new firmware and adding support for it.
We’ve all been on nails for the last weeks.
Yes, the biggest issue remaining is that charts in add-ons still don't work, but we knew that going in.
Thanks! Since I've figured out how to do the custom list, using a scam, phishing, malware and Steve Black's list (773,703 Blocked Domains), I am more than pleased with Diversion. 5.2 upgrade with just a click...How Easy Was That!
@thelonelycoder
Which version control are you using for your scripts? Diversion 5.1.1 libraries with 5.1.3 script seemed to have address my dnsmasq issue fully. So I am afraid now to move to any other version ...
It seems you've changed a lot of comments in various places between 5.1.1 and 5.1.3, so it's a large volume of differences there.
@thelonelycoder
I’m using a local only git copy.
Glad to hear it solved your issue.
When you have a less (or least?) busy moment, could you glance briefly at the differences in the supporting libraries between versions 5.1.1 and 5.1.3 ? Something might ring a bell regarding that dnsmasq issue that I was having with the custom DNS instance.
No rush, but just out of curiosity. It may be something that's good to double check.
I apologize for going right to you. I cannot find the new topic icon for the life of me. I'd appreciate anyone's help. I am dead in the water.
Asus AC3100, right from default settings. 192.168.50.1 is the IP. DNS1 is set to the same. No ads are blocked after clearing the browser cache (Opera and Edge). I am testing on:
speedtest.net
https://d3ward.github.io/toolz/adblock
It's late, I am tired, and my eyes are killing me.....this is not fun.
thanks all
nslookup says my Windows DNS is 192.168.50.1
An online DNS server check says my DNS is
AMANAHA-NEW - Amanah Tech Inc.104.245.144.50
IFNL-AS149.22.82.225
Nothing that affects Dnsmasq.
Thanks for checking! There gotta be some unfortunate shift in some memory addresses so things become screwy, but only intermittently!
I will keep checking newer Diversion versions from time to time, always ready to roll back to 5.1.1 - in case the issue resolves itself ...
It appears that Diversion blocks images necessary for search results on my Roku devices (effectively making search function unusable).
When browsing search results outside of my network I can see the images, but once connected to my Asus/Merlin router they are blank.
I have added 'images.sr.roku.com' to my allow list and processed it, but to no avail. Any suggestions?
Ads counter its not working any more after update i get this message when trying to enable loging
It does go down occasionally for updates. Try again later.
There's actually a banner on that page now - "upgrading", so it looks like the actual server is being upgraded rather than just the files there.
