Need help troubleshooting and fixing WiFi with Diversion. Currently with Diversion enabled WiFi does not work - none of the devices can connect to WiFi. Everything works fine on devices hard wired to the router.
I've been using Diversion + Skynet + Unbound for years with no issues. Few weeks/months ago when Diversion was updated and Merlin firmware was updated to 388.2_2, problems with WiFI started happening. After toggling scripts, I narrowed the issue down to Diversion. I started troubleshooting Diversion disabling different filters, but no luck. Disabling Diversion makes the WiFi work fine.
All the router/script settings, scripts, filters have been the same, the only difference is the firmware upgrade and the updated Diversion.
I have also tried resetting the router and reinstalling Diversion - same issue.
Any suggestions?
Any suggestions?
