ColinTaylor
Part of the Furniture
Can you SSH into the router and post the output of
cat /tmp/resolv.dnsmasqcat /tmp/resolv.dnsmasqadmin@DSL-AX82U-4B38:/tmp/home/root# cat /tmp/resolv.dnsmasq
server=127.0.1.1
It looks like DoT is still enabled. For all testing DoT and DNS Director must be disabled.Code:admin@DSL-AX82U-4B38:/tmp/home/root# cat /tmp/resolv.dnsmasq server=127.0.1.1 admin@DSL-AX82U-4B38:/tmp/home/root#
server=1.1.1.1
server=1.0.0.1
admin@DSL-AX82U-4B38:/tmp/home/root# nslookup assets.penny-arcade.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 0.0.0.0
Address 2: ::
admin@DSL-AX82U-4B38:/tmp/home/root# nslookup assets.penny-arcade.com 8.8.8.8
Server: 8.8.8.8
Address 1: 8.8.8.8 dns.google
Address 1: 104.21.64.223
Address 2: 172.67.156.39
Address 3: 2606:4700:3036::ac43:9c27
Address 4: 2606:4700:3030::6815:40df
admin@DSL-AX82U-4B38:/tmp/home/root# nslookup assets.penny-arcade.com 1.1.1.1
Server: 1.1.1.1
Address 1: 1.1.1.1 one.one.one.one
Server: 127.0.0.1
Address 1: 0.0.0.0
Address 2: ::
cat /etc/resolv.conf
netstat -nlp | grep :53
cat /etc/dnsmasq.conf
Code:cat /etc/resolv.conf
nameserver 127.0.0.1
Code:netstat -nlp | grep :53
tcp 0 0 192.168.0.1:53 0.0.0.0:* LISTEN 1826/ctrld
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 1826/ctrld
udp 0 0 192.168.0.1:53 0.0.0.0:* 1826/ctrld
udp 0 0 127.0.0.1:53 0.0.0.0:* 1826/ctrld
udp 0 0 192.168.0.1:5351 0.0.0.0:* 16462/miniupnpd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 1826/ctrld
udp 0 2496 0.0.0.0:5353 0.0.0.0:* 1826/ctrld
udp 0 0 0.0.0.0:5353 0.0.0.0:* 2189/avahi-daemon:
Code:cat /etc/dnsmasq.conf
admin@DSL-AX82U-4B38:/tmp/home/root# cat /etc/dnsmasq.conf
pid-file=/var/run/dnsmasq.pid
user=nobody
bind-dynamic
interface=br0
interface=pptp*
no-dhcp-interface=pptp*
no-resolv
no-poll
no-negcache
cache-size=1500
min-port=4096
bogus-priv
domain-needed
dhcp-range=lan,192.168.0.25,192.168.0.254,255.255.255.0,86400s
dhcp-option=lan,3,192.168.0.1
dhcp-option=lan,252,"\n"
dhcp-option-force=cpewan-id,vi-encap:3561,4,"FC3497"
dhcp-option-force=cpewan-id,vi-encap:3561,5,"FC3497584B38"
dhcp-option-force=cpewan-id,vi-encap:3561,6,"DSL-AX82U"
dhcp-authoritative
interface=br1
dhcp-range=br1,192.168.101.2,192.168.101.254,255.255.255.0,86400s
dhcp-option=br1,3,192.168.101.1
interface=br2
dhcp-range=br2,192.168.102.2,192.168.102.254,255.255.255.0,86400s
dhcp-option=br2,3,192.168.102.1
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
dhcp-script=/sbin/dhcpc_lease
script-arp
edns-packet-max=1232
no-resolv
server=127.0.0.1#53
add-mac
add-subnet=32,128
netstat -nlp | grep :53 shows that a process called ctrld is listening on the DNS service port (53). It should be dnsmasq./jffs/scripts/dnsmasq.postconf. They dump a lot in there.Yeah, lots of references to ctrld in there. Can I just nuke the whole file?Do clean out any crud in/jffs/scripts/dnsmasq.postconf. They dump a lot in there.
ctrld/internal/router/dnsmasq/dnsmasq.go at f1b8d1c4add2e5ba739f3adc0d6208413d3af656 · Control-D-Inc/ctrld
A highly configurable, multi-protocol DNS forwarding proxy - Control-D-Inc/ctrldgithub.com
You would have to re-install Diversion afterward. Maybe nuke the router to start fresh.Yeah, lots of references to ctrld in there. Can I just nuke the whole file?
You might be right. I've killed the file, re-installed Diversion and the ctrld reference is still there in netstat. What a ballacheYou would have to re-install Diversion afterward. Maybe nuke the router to start fresh.
Feels like they borrowed a lot from NextDNS client.
They put the “Control” in “Control-D”…You might be right. I've killed the file, re-installed Diversion and the ctrld reference is still there in netstat. What a ballache
ps | grep ctrld
admin@DSL-AX82U-4B38:/tmp/home/root# netstat -nlp | grep :53
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 5167/dnsmasq
tcp 0 0 192.168.0.1:53 0.0.0.0:* LISTEN 5167/dnsmasq
udp 0 0 127.0.0.1:53 0.0.0.0:* 5167/dnsmasq
udp 0 0 192.168.0.1:53 0.0.0.0:* 5167/dnsmasq
udp 0 0 192.168.0.1:5351 0.0.0.0:* 3845/miniupnpd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 2889/avahi-daemon:
Agreed! But you played your part too, Dave. Thanks again.Colin’s a legend.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
