Diversion Diversion stopped working in 386.1_2
you could try
touch /jffs/nmp_vc_json.js
i suppose. I'm not sure what that file is for, mine contains a list of MACS and vendor classes
Am I doing something wrong?
you could try
So the reason why I posted this is every thing else looks normal such as DHCPDISCOVER(br0) /DHCPOFFER(br0).. These are the only things that don't look normal. I've tried the command touch /jiffs/nmp_vc_json.js.. I will see if that does anything.
So mine did the same thing. It doesn't provide any notification or anything. I think it just creates the file & as long as you don't see an error its ok.
correct, it just creates an empty file. no idea if that's needed, but the errors complained it was missing. if it throws a different error it might need an empty json structure (I can post command for that)
My log is also flooded with these messages -
Mar 24 07:35:56 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:35:56 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:35:57 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:35:57 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:37:27 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:37:27 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:37:28 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:37:28 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:37:55 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:37:55 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Mar 24 07:38:57 RT-AC5300-DEN kernel: udb_ioctl_copy_out: no handler for ioctl 0xd:0x4
Mar 24 07:38:57 RT-AC5300-DEN kernel: udb_ioctl_copy_in: no handler for ioctl 0xd:0x3
Silly question, but where are you viewing these logs?
So I've installed Scribe add-on which allows you to download the log. Then my mac actually opens the file. Not sure if windows does that or you just use notepad or something else.
Ah right, I'm not using Scribe, I'm just looking at the standard log and I don't see anything like your seeing.
I see this error a lot also ---
Mar 24 18:20:37 RT-AC5300-DEN pixelserv-tls[2722]: create_child_sslctx: cannot find or use /opt/var/cache/pixelserv/_.onthe.io
Mar 24 18:20:37 RT-AC5300-DEN pixelserv-tls[2722]: tls_clienthello_cb: fail to create sslctx or cache _.onthe.io
I tried running this chown -R nobody /opt/var/cache/pixelserv .. maybe that helps.
I was having same issue and was able to fix it.
First I had to update to latest AMTM version. Afterwards, I had to manually update all entware packages in Diversion, because they were out of date. Even though there were no updates for Diversion.
Seems to be working fine so far.
