I'll look up how much they draw. Those heat sinks are 5W heat sinks. So I highly doubt that they are more than 2-3W ea. The regulator they used on these were the same ones on the Slot processors, just doubled up and requires a beefy 5V standby so it could handle the inrush current of the regulator. I pulled one of the flex ATX power supplies the 1 U had installed and they are 500W supplies.Your NIC ICs are around 45W alone, CPU has 45W DTP, count ~4W per RAM stick DDR3, each fan ~2W, the PSU is not 100% efficient, you have to add storage, everything else on the board on top. You are looking at 60-70W at idle minimum with this hardware.
Anyway, enjoy the DIY build. With your current 200Mbps ISP line though this "old gentleman" will do the all the routing you need like this:
I do a lot of file transfers inside the network. Plus since I'm updating, I minus well go the next real step up (10G) instead of making the network somewhat faster (2.5G)
I purchased a 2.5G network card to go into the pcie3 slot so it will talk to the cable modem at 2.5G. Next computers that will be built will be on current slot technology (PCIE5) instead of the outdated technologies they flooded the market place with (PCIE3)
