I bought DNS323 D link NAS. Due to my budget first I put single hard disk 500gb Seagate. After 2 months I bought another new hard disk (500GB Seagate) to add to make Raid 0. I already have data in my Hard disk 1. When I put the new Hard disk in slot 2. The program said, it will format new hard disk(s).
The program doesn't say it will format only new hard disk 2.
I was afraid it will erase all my data in hard disk 1. So I email to D link support and ask. The support said, it will format both hard disk. I have to back up my data from old hard disk 1. So I have to move the data to another 3rd Hard disk) and put the new hard disk. Then the DNS323 format hard disk. (I think it format only new). But i don’t know whether it format both or not as I did not leave some file in Hard disk 1. (I should have done this).
My question is, now I am using the Raid 0, and running both hard disk in DNS323. Hoping that one hard disk fail I can use another as backup. But if one hard disk fail, and I remove the failed hard disk, and buy a new hard disk to replace the defect one. Then it will ask again to back up both hard disk, so I need another (3rd Hard disk to move the data) while the DNS323 is formatting both hard disk.
Is there any way to instruct the DNS 323 to format only the newly replace hard disk.
Thank you in anticipation.
