nakany
Hello
I called my ISP and they told me they have nothing to do with IP reassignment schedules ( i have a dynamic IP and its changes every 24h).
Every day at ~15:46 I get a forced disconnection. How do I change it? They told me its a router setting. Where can I add the time for a forced disconnect? they also told me I can just unplug the power source and re-plug it after a few minutes at my preferable time. I did but nothing changed I also tried to enable Reboot Scheduler and still no luck.
Forced Disconnection Log
Just right now while typing my post I realised something odd. the date in my logs makes no sense.
Oct3? May 5? My System Time, Time Zone and daylight.. etc. is set probably. I don't get it. Is my Hardware busted?
Log dates from Oct 16 to Oct 19 15:48:08
Oct 3 22:45:13
Oct 17 16:25:32
Oct 18 05:23:36
Oct 18 23:00:05
Oct 19 03:05:27
Oct 19 05:00:22
May 5 07:05:02
May 5 07:05:41
Oct 19 05:03:07
Oct 19 15:48:08
End
Note
- Full Past 3 Days Log is attached
- ###### are syslog: wlceventd_proc_event)
This is a nightmare I can't endure. This stupid DSL-AC68U always pisses me off here and there its popping up some random pathetic issues, I own this since release. Big mistake.
Oct 19 15:46:11 DSL: Link up -> down
Oct 19 15:46:15 WAN Connection: Fail to connect with some issues.
Oct 19 15:46:16 nat: apply redirect rules
Oct 19 15:46:20 WAN Connection: Ethernet link down.
Oct 19 15:46:40 pppd[478]: Serial link appears to be disconnected.
Oct 19 15:46:46 pppd[478]: Connection terminated.
Oct 19 15:46:46 pppd[478]: Modem hangup
Oct 19 15:47:21 DSL: Link down -> up
Oct 19 15:47:25 WAN Connection: Ethernet link up.
Oct 19 15:47:25 rc_service: wanduck 227:notify_rc restart_wan_if 0
Oct 19 15:47:26 pppd[478]: Unable to complete PPPoE Discovery
Oct 19 15:47:28 pppd[10890]: pppd 2.4.7 started by admin, uid 0
Oct 19 15:47:28 pppd[10890]: Connected to dc:xxx:xxx:xxx:xxx:xxx via interface vlan3880
Oct 19 15:47:28 pppd[10890]: Connect: ppp0 <--> vlan3880
Oct 19 15:47:29 pppd[10890]: PAP authentication succeeded
Oct 19 15:47:29 pppd[10890]: peer from calling number xxx:xxx:xxx:xxx:xxx:xxx authorized
Oct 19 15:47:29 pppd[10890]: local IP address xxx.xxx.xxx.xxx
Oct 19 15:47:29 pppd[10890]: remote IP address xxx.xxx.xxx.xxx
Oct 19 15:47:29 pppd[10890]: primary DNS address xxx.xxx.xxx.xxx
Oct 19 15:47:29 pppd[10890]: secondary DNS address xxx.xxx.xxx.xxx
Oct 19 15:47:30 nat: apply nat rules (/tmp/nat_rules_ppp0_vlan3880)
Oct 19 15:47:30 WAN Connection: Fail to connect with some issues.
Oct 19 15:47:30 nat: apply redirect rules
Oct 19 15:47:31 wan: finish adding multi routes
Oct 19 15:47:31 miniupnpd[762]: shutting down MiniUPnPd
Oct 19 15:47:31 miniupnpd[10946]: version 1.9 started
Oct 19 15:47:31 miniupnpd[10946]: HTTP listening on port 37080
Oct 19 15:47:31 miniupnpd[10946]: Listening for NAT-PMP/PCP traffic on port 5351
Oct 19 15:47:35 WAN Connection: WAN was restored.
Oct 19 15:47:36 nat: apply nat rules (/tmp/nat_rules_ppp0_vlan3880)
Oct 19 15:47:38 nat: apply nat rules (/tmp/nat_rules_ppp0_vlan3880)
Oct 19 15:47:39 zcip client: configured xxx.xxx.xxx.xxx
Oct 3 22:45:13
Oct 17 16:25:32
Oct 18 05:23:36
Oct 18 23:00:05
Oct 19 03:05:27
Oct 19 05:00:22
May 5 07:05:02
May 5 07:05:41
Oct 19 05:03:07
Oct 19 15:48:08
End
Note
