Thanks!I think you need to take a step back and think about what DNS Director can and can't do.
Intercept port 53?
Hello, Can devices be forced to use the DNS from the router? I remember when I used to use Tomato, it had an option to intercept port 53, which prevented users from changing their devices DNS server and were forced to use whatever the router had. But, I see this option in Asus...and according...www.snbforums.com
Now I know why tampering DNS setting on the windows DNS setting = 8.8.8.8
and use a browser that supports DOH (Use secure DNS) will bypass DNS Director's global redirection.
That is the missing information that looking for so that I can close this topic.
Can you let the developer know this caveat and include this description:-
DNS Director
DNS Director allows you to force LAN devices to use a specific DNS server, which can be useful if you want to force them to use a filtering service that would block malicious or adult sites. You can set a global network-wide server, or client-specific servers. Beside the available presets you can also define up to three different custom servers to use.
A few special System options are available in the presets. "No Redirection" will bypass a global redirection, and "Router" will force clients to use the DNS provided by the router's DHCP server (or, the router itself if it's not defined).
