Yes. DoT is between your router and the internet DNS servers.I setup DNS-over-TLS, but they don't show on my Win 11 PC. The router's IP shows instead. Is this expected?
Thanks for the tip. It's just me in the house, and I have Malwarebytes and Kaspersky on my PC. I don't think I need more malware protection. Plus, most of my activities are on my iPhone and iPad, which I have Malwarebytes and Apple's Safari anti-malware settings.I find Cloudflare's documentation to be a bit confusing... I don't think 1.1.1.1 filters anything(?)
You may want to consider Cloudflare's DNS filtering options... block malware or block malware+adult content:
Set up
Learn how to set up Cloudflare's 1.1.1.1 DNS resolver for enhanced security and privacy. Protect against malware and adult content with easy configuration.developers.cloudflare.com
I use the following router WAN DNS configuration to block malware, i.e., block access to known malicious websites (no kids here):
This tool will give you feedback on your DNS configuration:
dnscheck.tools - check your dns resolvers
A tool to test for DNS leaks, DNSSEC validation, and morewww.dnscheck.tools
OE
For this type of protection the reaction time is most important. I don't know where Cloudflare gets the blocklists, but seems like they regularly score lower than other popular filtering DNS services.
Public DNS malware filters tested
How well do public DNS resolvers that claim to block malware domains really score? Which provider is the safest? We did the test!techblog.nexxwave.eu
Public DNS malware filters tested in 2024
How well do the largest public DNS resolvers that protect you against malware domains score in January 2024? We did the test!techblog.nexxwave.eu
AiProtection with once a month signature updates is mostly useless.
@OzarkEdge Do you have have random/intermittent but very short-lived outages with Quad9?Quad9. It may be time to settle on Quad9.
Hi there! It's a correct behavior because router can not propagate a DoT settings as they are managed by client. Technically your device is the client of router while router is a client of DoT. You can feel safe.I setup DNS-over-TLS, but they don't show on my Win 11 PC. The router's IP shows instead. Is this expected?
NextDNS. I have been using it for a while on several devices and it's great. It blocks about 32% of the traffic on my network.Hi there! It's a correct behavior because touted is nit a le to propagate a DoT settings as they are managed by client. Technically your device is the client of router while router is a client of DoT. You can feel safe.
I use for a couple of years the NextDNS service. They works awesome and has a checker page that allows you to ensure you are behind DoT.
Here it is https://test.nextdns.io/
It also supports profiling so that all my devices that goes outside router also behind NextDNS.
on another note, be advised, kaspersky is russian. i'd consider an alternative.Thanks for the tip. It's just me in the house, and I have Malwarebytes and Kaspersky on my PC. I don't think I need more malware protection. Plus, most of my activities are on my iPhone and iPad, which I have Malwarebytes and Apple's Safari anti-malware settings.
Yes, they are not to be trusted. Windows defender and common sense is usually enough.on another note, be advised, kaspersky is russian. i'd consider an alternative.
Thread starter | Title | Forum | Replies | Date |
R | Q on ASUSWRT 5.0, AX86U Pro guest Network DNS Settings | ASUSWRT - Official | 5 | |
DNSSEC DNS on RT-AX86U Pro causing some websites not to load properly | ASUSWRT - Official | 59 |
Welcome To SNBForums
