AdGuardHome DNS Resolution Not Working
Zim
Running into a bizarre issue since updating AGH to the latest version, v0.107.57 about a week ago. I have tried resetting the router, installing and uninstalling different scripts, in different order. In another thread, someone mentioned adding 127.0.0.1 and ::1 under "Allowed clients" list under "Access settings" in AGH. But no luck.
I'm running AGH + Unbound. When I run Unbound alone everything appears to be working fine, when I installed AGH the DNS queries stop going through OR are severely delayed. In AGH I see response times of 1,400+ms from 127.0.0.1:53535. Running netstat -nlp | grep :53 I do see AGH listening on port 53 and I see Unbound listening on 127.0.0.1:53535.
The upstream server in AGH is correctly set to:
127.0.0.1:53535
tcp://127.0.0.1:53535
Another thing I've noticed (since the AGH update) is when AGH + Unbound is running, Unbound stats for "Number of queries dropped because request list was full" is very high. About 60+% of the queries are being dropped. Without AGH the same number drops to less than 0.3%. I'm running AXE16000 so CPU and memory is not the issue.
Not sure what the issue is or to start to fix this.
