DonnyJohnny
mine have 5-8ms, server based in my countrySyslogs just now showed the Google OK DoH the rtt is really high around 120ms.
@MartinDEE Do you use VPN?
I installed beta 10 yesterday and 11 today, and have noticed that the dnscrypt process times out every 30mins or so. The only way to restore it is to restart the dnscrypt process by running ./manager dnscrypt-start - the output from the logs / shell:
U are supposed to keep Wan dns as Manual and blank.Quick question regarding dnscrypt config.
Should I change the Wan DNS server to 192.168.1.1?
It set to level3 DNS and Google. I have DNScrypt set to OpenDNS. The debug.opendns.com command don't always show dnscrypt enable.
Is this normal?
Now with the v2 version of dnscrypt-proxy, and amtm, Skynet, AB-Solution (Medium+) and openssh-sftp-server installed and TM's AI Protection activated in the meantime, still no issues with dnscrypt-proxy timing out after 30 minutes or so. It has been running for nearly 11 hours solid now
@bigeyes0x0 Pretty sure enabling the daemonize option was the fix as 24 hours have passed without crashes/hangs.
I have static ip and the gui does not let you save without entering dns info. I therefore have set the dns to my routers local ip. No problems running this way so far. Is this ok?Connect to DNS Server automatically in WAN DNS Settings should be set to 'No' and the fields should be left blank:
I am in WAN DNS settings. I have a static ip and not defining a DNS server in DNS settings cannot be accomplished. The gui will not save without an address. So I use the routers local address. ( I have no dns defined in lan settings.....just thought I would clarify this as well. )Are you in WAN DNS Settings? Then you should be able to save without filling DNS 1 or DNS 2.
If not, entering your routers' local IP in DNS 1 will just point back to dnscrypt-proxy, if I'm correct, so I don't think it matters. I had DNS 1 set to 192.168.1.1 previously myself, until I found out there was no need to. As long as there's no external DNS server in either of these fields, as that will cause DNS-leaks. If I recall correctly, I think @DonnyJohnny even mentioned it would be mandatory for OpenVPN setups to enter your routers local IP, but I don't use OpenVPN, so I can't verify.
Is this normal?
If not, the queries are not passing thru dnscrypt-proxy but the dns u defined . In this case, level3 and Google. Dns leak!!!
The "no-resolv" config in dnsmasq.conf should disable these WAN DNS settings so I really don't understand why you guys having dns leak
Welcome To SNBForums
