skeal
Part of the Furniture
Most likely a timing issue with the DNSCRYPT and the scripts: As DNSCRYPT starts quite late (with Entware) the earlier starting scripts do not find a DNS...![]()
This is correct. Dnscrypt also prevented privacy-filter from doing its comunication with the Internet. Also when updating settings on something else and applying would mess things up and required reboot to get things back to normal.
Edit: I also tried your uninstall procedure and it doesn't uninstall all versions and there are jffs script calls that need to be cleaned up as well. Just a heads up!
Edit: To be fair I completely removed all traces of dnscrypt rebooted and I will install latest version....to be continued...lol.
