DNSCrypt is reborn!
DonnyJohnny
New DNSCrypt v2 is here..
https://github.com/jedisct1/dnscrypt-proxy
For people who are interested in getting your hand dirty with this beta, my usual command to have a quick start below.
The precompiled binary is located at
https://github.com/jedisct1/dnscrypt-proxy/releases
Downland the arm version.
Environment I copy them to /jffs and beta 10. Modify to your needs.
wget https://github.com/jedisct1/dnscrypt-proxy/releases/download/2.0.0beta10/dnscrypt-proxy-linux_arm-2.0.0beta10.tar.gz -P /jffs
tar -zxvf /jffs/dnscrypt-proxy-linux_arm-2.0.0beta10.tar.gz -C /jffs && rm /jffs/dnscrypt-proxy-linux_arm-2.0.0beta10.tar.gz
Config the toml file
nano /jffs/linux-arm/dnscrypt-proxy.toml
(Listening port is 65053, not 53)
Move everything to /jffs/dnscrypt-proxy
cp -f /jffs/linux-arm/* /jffs/dnscrypt-proxy && rm -r /jffs/linux-arm
Create a simple bash script to start the app
nano /jffs/dnscrypt-proxy/start-dnscrypt.sh
Inside the sh file
#!/bin/sh
killall dnscrypt-proxy
logger -t dnscrypt-proxy "Starting DNSCrypt-proxy"
nohup /jffs/dnscrypt-proxy/dnscrypt-proxy -config /jffs/dnscrypt-proxy/dnscrypt-proxy.toml -loglevel 2 2>&1 | logger -t dnscrypt-proxy &
Save it.
Give exec right to sh file
chmod a+rx /jffs/dnscrypt-proxy/start-dnscrypt.sh
Add listening port to dnsmasq
nano /jffs/configs/dnsmasq.conf.add    (If file not found, create it)
Add this and save it.
server=127.0.0.1#65053
server=::1#65053      (If u are using ipv6)
server=/pool.ntp.org/8.8.8.8
server=/raw.githubusercontent.com/8.8.8.8
Restart dnsmasq service
service restart_dnsmasq
Go your router GUI,
Set the Wan and IPv6, to Manual configure and leave dns 1 and dns 2 EMPTY.
You may now start the sh file
You need to add the sh file to firewall-start script to allow it to load up during reboot.
nano /jffs/scripts/firewall-start      (If file not found, create it and give it exec right,   chmod a+rx /jffs/scripts/firewall-start )
Add this along first line. ( all sh file must have "#!/bin/sh" at first line)
#!/bin/sh
Save it.
Check your syslog.
It is recommended to create a swap file due to the program is resources hungry. I created my swap via ab-solutions or Skynet.
Personally some of my setting in toml file
daemonize = true
cache=false
Take note that installer in another thread by bigeye0x0 is working on it.
Read here.
https://www.snbforums.com/threads/dnscrypt-is-reborn.43869/page-5#post-374776
For a novice user like me, some instruction on installation and usage would be really useful.
The pre-compiled ARM binary does work on my RT-AC86U.
Do you mind sharing what steps you've taken to get it working? I get a fatal error when launching it:
./dnscrypt-proxy
[2018-01-13 16:26:17] [-] [NOTICE] [2.dnscrypt-cert.resolver2.dnscrypt.eu.] Valid cert found: [d616d26809d229a79457de073de8ebd83c24bff32bf7b406108b44da51fe3711]
[2018-01-13 16:26:17] [-] [FATAL] listen udp 127.0.0.1:53: bind: address already in use
What I did so far:
  • downloaded the precompiled binary
  • created a directory /etc/dnscrypt-proxy <-- useless, see post below
  • extracted the contents of the archive into that directory
  • changed permissions on the directory and its contents
  • made the binary executable
  • edited the .toml config file to use the closest dnscrypt server
  • tried to start dnscrypt-proxy
... which resulted in the error above.
I checked whether dns filtering is disabled, which is true, so I don't know what's running at 127.0.0.1:53. Searched the web for info on how to figure it out, but could only find netstat parameters which don't work on our limited version of netstat. htop didn't show any info, as far as I can tell, of which process is using port 53 on my RT-AC68U. Some pointers in the right direction would be appreciated.
You script guys are awesome!!:D Keep up the good work. This is getting closer all the time!
New one is written in GO, which consumes too much resources on embedded systems:(
That's too bad :(
Still curious how @XIII managed to get it running, as installing in /etc is not really an option. It's gone after a reboot and the precompiled binary quits if it's unable to find its config in /etc/dnscrypt-proxy.
./dnscrypt-proxy
What I did so far:
/etc/dnscrypt-proxy is useless on the router, once rebooted that directory is gone.
use symlink to do that.
u can install the script in your usb drive or jffs
the symlink to /tmp/etc/dnscrypt-proxy
eg. ln -s /jffs/dnscrypt-proxy /tmp/etc/dnscrypt-proxy
same time may need to add the symlink command at user script in service-start
and at wan-start, start the dnscrypt-proxy
i think you may still need to set server=127.0.0.1#65052 in /jffs/configs/dnsmasq.conf.add
do a reboot to try them.
i have not try it. you try and tell me. lol
by the way, there is already new commits for the dnscrypt-proxy v2. they change the directory requirement (/etc/dnscrypt-proxy) to same directory as dnscrypt-proxy (to find the dnscrypt-proxy.toml) See Link. Waiting for new compiled version. Unless someone know how to compile for us.
Thanks, I figured that out :D
@DonnyJohnny Thanks for your assistance. I think I'll wait for the next pre-compiled version as well. As you can see, my knowledge is limited, but it was worth a try.
Great. Another programmer who uses a less efficient language just "because they can", and they think it's cool. Sigh.
There’s a command line option to use a different path for the configuration log file.
I can’t try right now, but running the executable with —help might show it.
Furthermore, I used port 65053 instead of 53 (which I already did for the old version).
We still need to make dnsmasq listen to 127.0.0.1: port?
Alpha 5 is out. Looks better with csv link included inside the log.
I tested the alpha3 yesterday. Strangely only managed to use Cisco. The rest of the resolvers not working for me. I think it got something to do with dnssec validation. Hope this alpha5 works.
Also, yes, this GoLang version used more resources. But given the features it offers sound attractive. Let’s see how it go.
Question...
I used to be able to see the dnscrypt-proxy log. Like recieving cert and proxying to... now these I can’t see the log in syslog. Anyone know why?
