DNSCrypt is reborn!
Quick update for those interested: @DonnyJohnny and yours truly have been working behind the scenes to get dnscrypt-proxy working at boot and logging to syslog is now working as well. As far as I can tell, everything seems to work as expected now, but it has to be done manually. Getting this in an install script is a different story, I have no experience in creating such a script. We'll see what we can do with the old installer script to automate the install.
So, the good news: it's fully functional and seems stable and secure (no leaks), however, it might take some more time before we can provide an installer script to automate the installation. The latter might not be a bad thing, as it's currently in alpha stage meaning download urls for the pre-compiled binaries change frequently, which would be a hassle writing a script anyway.
To be continued...
To be continued...
Right on man!!
Alpha 6 out with query log. Working but I comment out.
Super fast release...
This dns protocol is sure moving very fast... first dnscrypt, then dns over tls... now dns over https.....
So exciting to see things moving so fast...
I planning to try unbound and dns over tls.
Anyone can give me a quick link on how to set it up in asuswrt-merlin?
Unbound is in the entware-ng repository.
For the configuration you can get some inspiration from here: https://calomel.org/unbound_dns.html
One of the things I needed to add was this:
username: ""
I should experiment some more with this as well... (but can't find/make the time right now)
DNSCrypt-proxy v2 has just left alpha stage, beta 1 has been released.
Latest feature introduced is, when multiple servers are in dnscrypt-proxy config, it will now test for latency for all servers configured and will use the fastest one to resolve dns queries.
Pre-compiled binary can be found here: https://github.com/jedisct1/dnscrypt-proxy/releases/latest
While it is cool to use 60 dns resolvers but sending queries to 60 dns resolvers is a bit crazy. I now pre-select 3 fastest dns resolvers as failover. Lol...
This is cool and easy to use...
Great. Another programmer who uses a less efficient language just "because they can", and they think it's cool. Sigh.
To be honest, it ain't that bad. I haven't seen it using more than 4.7 Mb of resources (mostly 3-4 Mb) and given the (increasing) amount of functionality, I can totally live with that. I'll try to do some dns benchmarks tomorrow to see how it behaves when under load. So far, I haven't had a single moment I felt like it was a memory hog which degrades my RT-AC68U's performance.
It doesn't test all the available servers in the sources list, it tests the servers configured in [Servers] section in dnscrypt-proxy.toml, so only the ones you've pre-configured. It uses the fastest and keeps the others as failover.
Nah.. my static list has only 1 pre-configured resolver. It did test the whole csv list. Notice the 60 live server. It generated a whole list of ping test which is more than 10000 character for me to paste here. Btw Cisco for me is 3ms. What more can I ask for?
Jan 18 06:07:16 dnscrypt-proxy: [2018-01-17 22:07:16] [-] [NOTICE] Server with the lowest initial latency: cisco (rtt: 3ms)
Jan 18 06:07:16 dnscrypt-proxy: [2018-01-17 22:07:16] [-] [NOTICE] dnscrypt-proxy is ready - live servers: 60
What does it mean that the beta has no local DNSSEC validation?
I think it will do the job of dnsmasq. Validating the dnssec
Asuswrt-merlin already sup-port dnssec under LAN, DHCP Server.
Has he implemented the option to ignore timestamps from certs yet? That is necessary to properly integrate it for embedded devices without a RTC.
