Dnscrypt log timestamps not synced with ntp or dnsmasq log timestamps
dugaduga
Any way to ensure dnscrypt log timestamps are synced up with dnsmasq/ntp? I used ntpmerlin, the problem persisted; I removed ntpmerlin, enabled asuswrtmerlin's built in ntp option in the ui and still dnscrypt logs are not syncing up properly. [related]
I install the timezone option within the dnscrypt installer. This creates a symbolic link to the system and should hopefully resolve your logging issues.
 Info:  Detected ARMv8 architecture.
 Info:  JFFS custom scripts and configs are already enabled.
 Info:  DNS Environment is Ready.
 Info:  DI_VERSION=v2.1.8
 Info:  DNSCRYPT_VER=2.0.45
 Info:  Manager file is Up-To-Date!
 Info:  Choose what you want to do:
  1) Install/Update dnscrypt-proxy
  2) Uninstall dnscrypt-proxy
  3) Configure dnscrypt-proxy
  4) Set timezone
  5) Unset timezone
  6) Install (P)RNG
  7) Uninstall (P)RNG
  8) Install swap file
  9) Uninstall ALL
  b) Backup
  q) Quit
 =>  Please enter the number that designates your selection:, [1-9/b/q]: 4
 Info:  This operation allows you to set your router
 Info:  timezone for background services and processes
 =>  Do you want to proceed? [y/n]: y
 Info:  manager is up to date. Skipping...
 Info:  Downloading tzdata-2018c-1-any.pkg.tar.bz2
 Info:  Available timezones/locations:
  1) Africa/Abidjan
  2) Africa/Accra
  3) Africa/Addis_Ababa
  4) Africa/Algiers
  5) Africa/Asmara
  6) Africa/Asmera
.....shortened for readability.......................
  581) US/Eastern
  582) US/Hawaii
  583) US/Indiana-Starke
  584) US/Michigan
  585) US/Mountain
  586) US/Pacific
  587) US/Pacific-New
  588) US/Samoa
  589) UTC
  590) Universal
  591) W-SU
  592) WET
  593) Zulu
 =>  Select your timezone/location, [1-593]: 581
 Info:  Eastern selected
 Info:  init-start file already configured
 Info:  Configure services-stop file
 Info:  Operation completed. You can quit or continue
Here is what it looks like when i installed it on my setup.... my logs are properly timestamped with my appropriate timezone attached.
