Could someone assist me with an issue i'm having with my Asus RT-AX88U?
For the past month since i've had this router, I find that router intermittently plays up and stops anything from connecting to WAN.
I spent last month troubleshooting and only pattern I could find was that when I connect either of the two work laptops.
Checking the log around the time I try to connect these devices, I found the following:-
After this, anything connected to router just refuses to work resulting in a reboot.
I googled the recursive error and found this:
The above makes sense to me as the domain of our work laptops, we don't own and doesnt exist (don't ask )
The above answer is talking about removing from configuration or something as in:
"It is not suitable for use by dnsmasq as an upstream server and should be removed from the configuration"
Any ideas if i'm on the right track?
dnsmasq-dhcp[2328]: Ignoring domain x.com for DHCP host name 8P9JNH2
dnsmasq-dhcp[2328]: DHCPACK(br0) 192.168.100.34 28:c6:3f:18:68:48 8P9JNH2
dnsmasq[2328]: nameserver 192.168.100.1 refused to do a recursive query
Q: Dnsmasq sometimes logs "nameserver xxx.xxx.xxx.xxx refused
to do a recursive query" and DNS stops working. What's going on?
A: Probably the nameserver is an authoritative nameserver for a
particular domain, but is not configured to answer general DNS
queries for an arbitrary domain. It is not suitable for use by
configuration. Note that if you have more than one upstream
nameserver configured dnsmasq will load-balance across them and
it may be some time before dnsmasq gets around to using a
particular nameserver. This means that a particular configuration
may work for sometime with a broken upstream nameserver
configuration.
