I’m having an issue customizing dnsmasq.
I have a new ASUS RT-N16 and installed Asuswrt-Merlin Version 3.0.0.2.246.19 after my testing showed that the DD-WRT versions for this router have wireless issues that are not exhibited by ASUS' versions of the firmware.
I have successfully configured dnsmasq on both Redhat Linux and DD-WRT to provide DNS to my home office network and would like to do the same on the new RT-N16. The 'README' file with the 3.0.0.2.246.19 version indicates that the dnsmasq.conf and the hosts file can be appended or replaced by placing them in the /jffs/configs directory. I created the two files appending their filenames with ".add" as instructed but after a reboot neither the /etc/dnsmasq.conf file nor the /etc/hosts file was appended. FYI: Before you ask, both files I added are still in the /jffs/configs directory after the reboot.
Is there something I missed in the configuration? If required, I could write a script to append the files and then restart the daemon but this way looked simpler. Also, are files appended/replaced before the daemons start?
Thanks in advance for any help that is provided.
