Pedro Faria
Hello
I did some searching in the forum but I didn't find anything particularly related to what I'm looking to do.
Running an R8900, I just updated the router to the newest available version, and just added entware to it. (thank you for that capability)
I used to run pfsense, and had the ability to resolve specific external web/dns names to an internal IP.
I added two packages after the install, adsuck, and dnsmasq, not sure if thy conflict. when I went to start the dnsmasq it said
dnsmasq: failed to create listening socket for port 53: Address already in use
and a netstat -tuln | grep LISTEN revealed
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN
tcp 0 0 :::53 :::* LISTEN
any input or step in the right direction would be appreciated
Thank you
QuattroCS
Thank you
QuattroCS
