dnsmasq-script errors
Nitr0
I saw these in several posts regarding firmware updates between 384.13 and 384.14 but I never saw an answer. I'm running 384.15 on an AC88 and these started when I changed one of my AC68U routers to aimesh today. Is there any way to find the root cause and fix the errors?
Mar 28 21:00:14 dnsmasq-script[30987]: [SEND_AMAS_NODE_EVENT:(4684)] ERROR connecting:No such file or directory.
Mar 28 21:00:14 dnsmasq-script[30987]: connect error: No such file or directory
Mar 28 21:01:42 dnsmasq-script[30987]: connect error: No such file or directory
Mar 28 21:01:42 dnsmasq-script[30987]: [SEND_AMAS_NODE_EVENT:(4684)] ERROR connecting:No such file or d
Appears to be AiMesh closed source code spewing those messages.
https://ftp.snbforums.com/threads/s...r-connecting-no-such-file-or-directory.62407/
So I factory reset my AC88 last weekend and did a clean rebuild on 384.17. These messages started happening again after I installed Entware. I hadn't even installed another package and they started occurring. Is there a way to stop them or should I just ignore them?
How did you install Entware? Did you format the JFFS partition? Did you format the USB drive on a computer first? :)
yes you can filter them out of your main syslog- install scribe via amtm - install uiscribe via amtm
create file called "amas" with following content
destination d_dnsscripterror{
    file("/opt/var/log/dnsscripterror.log");
filter f_dnsscripterror{
    program("dnsmasq-script");
log {
    source(src);
    filter(f_dnsscripterror);
    destination(d_dnsscripterror);
    flags(final);
#eof
Put that file "amas" into /opt/etc/syslog-ng.d
restart syslog-ng via scribe menu in amtm
I've been using it for a while and then just factory reset. After factory reset I used AMTM to
log {
    source(src);
    flags(final);
#eof
Thanks, I've placed the file and restarted syslog-ng.d. I'll keep an eye on it but after 5-10 minutes I'm so far clear.
