DNSMasq seems to ignore dhcp-host option in dnsmasq.conf.add
busch09
trying to set static hostnames, IPs by mac-address with dhcp-host=ab:cd:ef:gh:ij,Server1,192.168.1.10 .
Setup as per Merlin's tutorial and then made executable -rwxrwxrwx.
https://github.com/RMerl/asuswrt-merlin/wiki/Custom-domains-with-dnsmasq
-rwxrwxrwx 1 admin root 2808 Mar 3 21:20 dnsmasq.conf.add
-rwxrwxrwx 1 admin root 0 Mar 3 09:56 resolv.dnsmasq
-rwxrwxrwx 1 admin root 3641 Mar 3 13:18 hosts.dnsmsq
My dnsmasq.conf (as generated by asus merlin 384.9) , my dnsmasq.conf.add is at the end
https://pastebin.com/3yuA7jdy
Log file:
https://pastebin.com/Nac39WUn
My dnsmasq.conf
https://pastebin.com/5Jz2j0Q4
  • Any error messages in /tmp/syslog.log?
  • What's up with the CODE tags?
  • Does dnsmasq ignore your dhcp-host specification for the router LAN interface which is the DHCP server?
So you have defined a whole dnsmasq.conf and an add. version? Thinking add is only supported if you are not defining the whole file, i.e. it only works if you are adding to the stock file.
You can use an include file off the main one to achieve separation of config if you want that.
