Unbound DNSSec with unbound_manager?
dominik
Hello,
I'm using latest merlinwrt 388.1 on AX86U with unbound manager (v3.22) and can't get DNSSec to work :(
With unbound turned on DNSSec validation is gone, please take a look at this example:
Bash:
admin@router:/tmp/home/root# dig @192.168.1.1 +adflag example.org A
; <<>> DiG 9.18.1 <<>> @192.168.1.1 +adflag example.org A
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 41136
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1280
;; QUESTION SECTION:
;example.org.                   IN      A
;; ANSWER SECTION:
example.org.            14040   IN      A       93.184.216.34
;; Query time: 1 msec
;; SERVER: 192.168.1.1#53(192.168.1.1) (UDP)
;; WHEN: Wed Jan 04 11:48:50 CET 2023
;; MSG SIZE  rcvd: 56
This returns answer without dnssec validation (no AD flag).
Trying same thing on google nameservers (also quad9 are ok):
Bash:
admin@router:/tmp/home/root# dig @8.8.8.8 +adflag example.org A
; <<>> DiG 9.18.1 <<>> @8.8.8.8 +adflag example.org A
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 45771
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
; EDNS: version: 0, flags:; udp: 512
;example.org.                   IN      A
;; ANSWER SECTION:
example.org.            13696   IN      A       93.184.216.34
;; Query time: 9 msec
;; SERVER: 8.8.8.8#53(8.8.8.8) (UDP)
;; WHEN: Wed Jan 04 11:48:59 CET 2023
Also it works when unbound is stopped:
Bash:
; <<>> DiG 9.18.7 <<>> @192.168.1.1 +adflag example.org A
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56427
;example.org.                   IN      A
;; ANSWER SECTION:
example.org.            84638   IN      A       93.184.216.34
;; Query time: 0 msec
;; WHEN: Wed Jan 04 12:59:53 CET 2023
I noticed that unbound in it's options recommends turning off DNSSec and DNS Rebind protection:
no matter what is selected there AD flag is missing when unbound is working.
I also checked advanced options for unbound manager, also with DoT - but still AD flag with running unbound is lost :(
Anybody got it working with DNSSec?
No need for DNSSEC with Unbound as it works as a forwarding resolver. I believe it uses its own secure communications.
I am running on AC86U. Can you try to run the below command and see if you get the same similar output?
admin@RT-AC86U-DBA8:/tmp/home/root# unbound-control get_option port
53535
admin@RT-AC86U-DBA8:/tmp/home/root# dig +dnssec -p 53535
; <<>> DiG 9.18.7 <<>> +dnssec -p 53535
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 20668
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 14, AUTHORITY: 0, ADDITIONAL: 1
; EDNS: version: 0, flags: do; udp: 1428
;.                              IN      NS
;; ANSWER SECTION:
.                       323476  IN      NS      i.root-servers.net.
.                       323476  IN      NS      j.root-servers.net.
.                       323476  IN      NS      k.root-servers.net.
.                       323476  IN      NS      l.root-servers.net.
.                       323476  IN      NS      m.root-servers.net.
.                       323476  IN      NS      a.root-servers.net.
.                       323476  IN      NS      b.root-servers.net.
.                       323476  IN      NS      c.root-servers.net.
.                       323476  IN      NS      d.root-servers.net.
.                       323476  IN      NS      e.root-servers.net.
.                       323476  IN      NS      f.root-servers.net.
.                       323476  IN      NS      g.root-servers.net.
.                       323476  IN      NS      h.root-servers.net.
.                       323476  IN      RRSIG   NS 8 0 518400 20230114170000 20230101160000 951 . jjT6lEOHlA/x47a2y++jVTGdYV8aJ9g4Pworcv1lHDkzQWEIX4/ie+Nk FjXfzUEWxKGXbDluX/AT1aVum48O8eYUO4gkJ1yOhz6y593t6iFWyw+G cVmVrRU8bOdAmizX6/qxjB4FIiUrepzuhko8MuZgRt5+LasuHMKBTGBu sjnBMkLBd6K6bivYGgmZ10jagUxSyfmqeJFanMcBTO5ysp+nkavxRu2r 4Y1DrGldgMKFpyyYEQK0bx4DJRAmM2Eoqvzped1OukI/7+kGSLpY5q1J vwG2T4cdv55nbcXI/lGFVkALTMCI5ubANbVA0skZN0nibI2VtHOb4tqe sHl+lw==
;; SERVER: 127.0.0.1#53535(127.0.0.1) (UDP)
;; WHEN: Wed Jan 04 20:53:45 MYT 2023
;; MSG SIZE  rcvd: 525
You can also run this to check the query counter
unbound-control stats_noreset | grep -F num.query.flags.AD
One of my services checking for dnssec flags and won't start without it :( It will fail to start doing dnssec validation and script is looking exactly for this flag inside queries
trying:
admin@router:/tmp/home/root# unbound-control get_option port
53535
admin@router:/tmp/home/root# dig +dnssec -p 53535
;; communications error to 9.9.9.9#53535: host unreachable
;; communications error to 149.112.112.112#53535: host unreachable
;; communications error to 127.0.1.1#53535: connection refused
;; no servers could be reached
this probably looks for /etc/resolv.conf nameservers (now quad9) and trying to query all of them on given port, I guess that unbound is listening on 127.0.0.1:53535 (not 127.0.1.1)
admin@router:/tmp/home/root# dig +dnssec @127.0.0.1 -p 53535
; <<>> DiG 9.18.7 <<>> +dnssec @127.0.0.1 -p 53535
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14811
; EDNS: version: 0, flags: do; udp: 1472
;.                              IN      NS
;; ANSWER SECTION:
.                       516072  IN      NS      f.root-servers.net.
.                       516072  IN      NS      g.root-servers.net.
.                       516072  IN      NS      h.root-servers.net.
.                       516072  IN      NS      i.root-servers.net.
.                       516072  IN      NS      j.root-servers.net.
.                       516072  IN      NS      k.root-servers.net.
.                       516072  IN      NS      l.root-servers.net.
.                       516072  IN      NS      m.root-servers.net.
.                       516072  IN      NS      a.root-servers.net.
.                       516072  IN      NS      b.root-servers.net.
.                       516072  IN      NS      c.root-servers.net.
.                       516072  IN      NS      d.root-servers.net.
.                       516072  IN      NS      e.root-servers.net.
.                       516072  IN      RRSIG   NS 8 0 518400 20230117050000 20230104040000 951 . GCWB4LpmDiyF/elU8+NuAhg/Q6RFCHWIQTT09TOOErpP4TZbD99n7/Kw uQcR7OUcVqwpnEaIu+DSWXye5Ee1n4ZmZipsg3JISJDIj41lFsk3t5D8 IRtPJpedAvrehz7hnn4yt7F5wm5N3s5R0PyehS+B8Pxb9tIpSyzt6nB1 B0IS0zugvOTfoJ3LAEkvnKo+q/PGcykjAtm5ZIA82VsVOR+eNXeWV2vC G2Mxx5ld0A7grTEBSracozCDak4SpbQ48b5aoTiR5o9JblZdJn0diqwr 1ihBXE2DcqFPKDNqYdf5S5L6ep36CEv92SPLPhWz4dAwhVWOsOH5gJhW BawM9g==
;; WHEN: Wed Jan 04 14:09:12 CET 2023
this answer got AD flag :/
other settings:
admin@router:/tmp/home/root# unbound-control stats_noreset | grep -F num.query.flags.RD
num.query.flags.RD=173
admin@router:/tmp/home/root# unbound-control stats_noreset | grep -F num.query.edns.DO
num.query.edns.DO=41
admin@router:/tmp/home/root# unbound-control stats_noreset | grep -F num.query.edns.present
num.query.edns.present=43
I also increased verbosity to 3 and checked that unbound receives queries (no errors):
Jan 04 13:55:40 unbound[3965:0] query: 127.0.0.1 example.org. A IN
Jan 04 13:55:40 unbound[3965:0] debug: worker request: max UDP reply size modified (4096 to max-udp-size)
Jan 04 13:55:40 unbound[3965:0] reply: 127.0.0.1 example.org. A IN NOERROR 0.000000 1 227
Seems that unbound is responding with ad flag but only on 127.0.0.1:53535, but same thing is lost at router address :/
dnsmasq is likely not passing the ad flag since unbound_manager disables dnsmasq’s dnssec for caching purposes. The dnsmasq proxy-dnssec option would be handy but might not play well with the whole picture.
