It bypasses your ISP’s DNS servers, but you still must send your Unbound DNS queries through your ISP’s network.I thought unbound bypasses ISP for DNS?
So if you use CLoudflare DNS set up on the router or your phone, your queries don't go though ISP?It bypasses your ISP’s DNS servers, but you still must send your Unbound DNS queries through your ISP’s network.
Khadanja, they probably are blocking your ISP ASN, in which case even your IP would be blocked. This isn't something you can control. When you are using unbound recursively, YOU meaning you and your IP are your own DNS server. Using your hostname. When you access it using the forward method, you are asking those servers to tell you about that domain.Works if I do this. How to add multiple domains? Also, why does it work this way? If my ISP is blocking it, I thought unbound bypasses ISP for DNS?
You could also make sure you are not country blocking with skynet. This has been known to cause issues when using unbound root servers.Works if I do this. How to add multiple domains? Also, why does it work this way? If my ISP is blocking it, I thought unbound bypasses ISP for DNS?
not blocking any country. How to add multiple domain in forward zone? Tried but unbond complaining about duplicate forward-tls-upstream & forward-zone#DoTYou could also make sure you are not country blocking with skynet. This has been known to cause issues when using unbound root servers.
after the first forward arguement only start with name.not blocking any country. How to add multiple domain in forward zone? Tried but unbond complaining about duplicate forward-tls-upstream & forward-zone#DoT
& now getting /opt/var/lib/unbound/unbound.conf:192: error: forward name override, there must be one name for one forward-zoneafter the first forward arguement only start with name.
e.g.
forward-zone:#DoT # v1.08 Add #DoT edit marker v1.05 DNS-Over-TLS support ##only put this argument once.
name: "nest.gq" <<------ this part says we want unbound to ask the servers below for information about this domain, thus skipping your ISP's network.
forward-tls-upstream: yes
forward-addr: 1.1.1.1@853#cloudflare-dns.com
forward-addr: 1.0.0.1@853#cloudflare-dns.com
forward-addr: 9.9.9.9@853#dns.quad9.net
forward-addr: 149.112.112.112@853#dns.quad9.net
forward-addr: 2606:4700:4700::1111@853#cloudflare-dns.com
forward-addr: 2606:4700:4700::1001@853#cloudflare-dns.com
forward-addr: 2620:fe::fe@853#dns.quad9.net
forward-addr: 2620:fe::9@853#dns.quad9.net
so apparently you have to do them all individually.tried that
forward-zone:
Tried that already exactly like you have typed but get this error -so apparently you have to do them all individually.
Code:forward-zone:#DoT # v1.08 Add #DoT edit marker v1.05 DNS-Over-TLS support name: "nest.gq" <<------ this part says we want unbound to ask the servers below for information about this domain, thus skipping your ISP's network. forward-tls-upstream: yes forward-addr: 1.1.1.1@853#cloudflare-dns.com forward-addr: 1.0.0.1@853#cloudflare-dns.com forward-addr: 9.9.9.9@853#dns.quad9.net forward-addr: 149.112.112.112@853#dns.quad9.net forward-addr: 2606:4700:4700::1111@853#cloudflare-dns.com forward-addr: 2606:4700:4700::1001@853#cloudflare-dns.com forward-addr: 2620:fe::fe@853#dns.quad9.net forward-addr: 2620:fe::9@853#dns.quad9.net forward-zone: name: "some.other.site.com" forward-tls-upstream: yes forward-addr: 1.1.1.1@853#cloudflare-dns.com forward-addr: 1.0.0.1@853#cloudflare-dns.com forward-addr: 9.9.9.9@853#dns.quad9.net forward-addr: 149.112.112.112@853#dns.quad9.net forward-addr: 2606:4700:4700::1111@853#cloudflare-dns.com forward-addr: 2606:4700:4700::1001@853#cloudflare-dns.com forward-addr: 2620:fe::fe@853#dns.quad9.net forward-addr: 2620:fe::9@853#dns.quad9.net
Which means you have to repeat the same arguements for each one.
the real question is, IS this a legit unbound error, or one generated by unbound manager?Tried that already exactly like you have typed but get this error -
***ERROR unbound configuration contains DUPLICATES - use option 'vx' to correct 'unbound.conf' or 'rl' to load a valid configuration file
4 forward-tls-upstream:
3 forward-zone:
I am able to run multiple forwardzones in all my unbound configurations. Even the one above. maybe @Martineau could explain this limitation in his manager.Tried that already exactly like you have typed but get this error -
3 forward-zone:
You could make a separate include file which should be impervious to the scripts forward zone check.In my unbound.conf file another zone Stubby is commented out which suggests that multiple should work.
#forward-zone:#Stubby # v1.08 Add #Stubby edit marker
#name: "."
#forward-addr: 127.0.1.1@5453
#forward-addr: 0::1@5453 # integration IPV6
#@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ # v1.05 Martineau
Bingo.Create a separate .conf file and just add the forward zones there and then include it in the mail .conf file?
Worked!!!! Thanks!! I am hosting AdGuard on ad.nest.gq & using it on my iPhone by creating a custom profile for DoH when connected to mobile data but that won't work anymore . Most likely my ISP has started blocking all these .gq, .ml free domains for whatever reason.Bingo.
Welcome To SNBForums
