normal scheduled reboot to keep things running smooth
The flash chip used by the RT-AX88U, for example, has a rated write endurance of 100K cycles.I don't believe '100's of thousands of writes to each cell', is accurate. It may have been 15 years ago, but they don't build them like that today.
I'd be very surprised if each cell had much more than 10,000 writes, actually, at most.
Read this, apparently nothing bad happens: https://www.snbforums.com/threads/the-uptime-contest.62711/What happens if you don't reboot for a week/month? Do you have any bad experience with long uptime?
I guess for these diminutive sizes, SLC is still actively used.
No, SLC isn't for capacity, it is for endurance (and it is (or was) faster than any multi-cell approach used commercially today).
It was specified in the datasheet that I linked.Don't assume it is SLC flash, you need to check the data sheet for the part itself.
Welcome To SNBForums
