After the SNB review I bought the R7800 yesterday for ~usd220, so far I'm more than happy for its quality and performance compare to my ancient old E4200 v1.
However, the file transfer speed between pcs seems like there's some room for improvement, for a single large file it consistently transfer at 50-52MB/s which is ok but I expected the speed should sit around 70-80MB/s.
**I virtually place the R7800 next to my laptop in my room ~3M x 2.5M**
Here is how I link up all the devices on my network:
ISP Converter (Fibre to home) --> Pfsense Box (build it myself) with Squid(guard), Suricata, PFblockerng enabled --> Unmanaged 24 ports Switch --> R7800 (AP Mode 5Ghz Only Channel 44 according to WiFi analyzer app it operates across 42-46)
--> E4200 (AP Mode 2.4Ghz Only)
Here are my question: (Only concern on the AC performance with my Dell XPS15 9550 using BCM43602 wifi)
1) Does AP mode cripple the performance?
2) Is my file transfer speed normal? (According to Anandtech http://www.anandtech.com/show/10116/the-dell-xps-15-9550-review/8 with my laptop model it can perform at 652 Mbps)
3) Any tips and tricks can improve the file transfer speed?
Thanks in advance!!!
