@maxbraketorque
I've been happy with my Main/AP setup, and I was curious how your setup has been?
Have you "upgraded" to RMerlin fw, or have you found benefits in the current official/beta fws?
Well, "significantly less expensive at this time" depends on where in the world you are. In the U.S., the GT-AX6000 is the most expensive of the three (on Amazon, but there's rarely much difference between online stores). AX86U Pro is $250, AX88U Pro is $270, and the GT-AX6000 is $330. Previously, someone said the situation is the reverse in Norway, and I'm guessing without evidence that's probably true in most of Europe. I would expect (again without evidence) Canadian pricing to be similarly structured to the U.S.I use the ASUS main/AP mode for my two router home network. This setup requires wired backhaul. It lacks some features of Aimesh, but its 100% reliable, and I have full control over the radio settings on the AP. I replaced both the main and the AP RT-AC86Us with GT-AX6000s. My home network already incorporates a multigig switch for the wired network, so moving from the RT-AC86U to the GT-AX6000 allowed me to bring the wireless part of the network up to 2.5 gbps. I'm running the current latest beta firmware - 9.0.0.6.102.4856. A few thoughts on the move to the GT-AX6000 main/AP combo:
- The GT-AX6000 is definitely larger than the RT-AC86U, but its not really that much more of an eyesore than the RT-AC86U because the body of the GT-AX6000 sits horizontal rather than vertical. If a set of more normal looking antennas were used, it would look less obtrusive than the RT-AC86U.
- N and AC wireless range and speed at long range are about the same as my RT-AC86U. No surprise here as the RT-AC86U is known to have excellent wireless range, and I guess the good news is that the GT-AX6000 range is as good rather than worse.
- Maximum wireless speeds are now of course higher due to 2.5 gbps networking and AX mode, but not a lot higher. Close range, large file transfer speeds between my wired server and my wireless 3x3 AC laptop went from 80 MB/sec with the RT-AC86U to 90 MB/sec with the GT-AX6000. I wouldn't expect my AX laptop to be any faster because its only 2x2 (which now seems to be the standard for built-in AX wifi, even on Macs). I have yet to try a folder of small files which may be more relevant because backup software (which everyone should be using) is often chatty and uses lots of small transfers.
- I've not yet experimented to see if my AX devices have better range in AX mode than in AC mode. I may try that at some point.
- Not surprisingly, the router GUI runs noticeably faster on the GT-AX6000 despite the RT-AC86U GUI being no slouch.
- The ROG web GUI design is annoying.
- I'm just beginning to explore the beta firmware features. Not much to say here yet except that the Network Map is still broken (stops updating after a while) with the new beta firmware. I guess ASUS is never going to fix this.
- Based on my experience thus far, I would say there is no clear benefit to the upgrade except to have access to the next generation ASUS firmware which hopefully will be significantly better.
- If someone wants to get one of the ASUS Pro-level routers, I see no reason not to choose the GT-AX6000 for dual band needs because it has all the features and capability of the RT-AX88U Pro and RT-AX86U Pro but runs significantly less expensive at this time.
In Canada the GT-AX6000 is currently the least expensive of the three (on Staples) and almost in par with your US price. The AX86U Pro is $390 Cdn, AX88U Pro is $400 Cdn, and the GT-AX6000 is $350 Cdn. Therefore ASUS have clearly different pricing policies in different countries.Well, "significantly less expensive at this time" depends on where in the world you are. In the U.S., the GT-AX6000 is the most expensive of the three (on Amazon, but there's rarely much difference between online stores). AX86U Pro is $250, AX88U Pro is $270, and the GT-AX6000 is $330. Previously, someone said the situation is the reverse in Norway, and I'm guessing without evidence that's probably true in most of Europe. I would expect (again without evidence) Canadian pricing to be similarly structured to the U.S.
Whiskey. Tango. Fox. That's ~$65UD cheaper in Canada than the U.S. for the AX6000, while the AX86U Pro is ~$45UD more expensive in Canada than the U.S.In Canada the GT-AX6000 is currently the least expensive of the three (on Staples) and almost in par with your US price. The AX86U Pro is $390 Cdn, AX88U Pro is $400 Cdn, and the GT-AX6000 is $350 Cdn. Therefore ASUS have clearly different pricing policies in different contries.
ASUS' marketing works in mysterious ways!!!Whiskey. Tango. Fox. That's ~$65UD cheaper in Canada than the U.S. for the AX6000, while the AX86U Pro is ~$45UD more expensive in Canada than the U.S.
Maybe they perceive U.S. gamers as more willing to shell out for a "gaming" router. Clearly "best value" depends on where you live.
That depends ENTIRELY on your use case.Yes, marketing is mysterious.
That doesn't stop me from seeing the true value of certain models. Even when more expensive, the GT-AX6000 is still the superior router today. Well worth a few extra dollars when you'll be using it for the next few years (a coffee or two a year difference, at the most).
What's the advantage of the AX6000 for me?
What hardware GT-AX6000 is better than hardware RT-AX88U Pro and RT-AX86U Pro?Better hardware is objectively better.
My ISP download speed has been ~300 Mbps for about 5 years now and I don't need or plan to increase it in the next few years.In that time frame, ISP speeds change, client devices change, and most importantly, our expectations of our equipment changes too.
Sorry, with the lone exception of the 2.5Gbit WAN port, AFAIK, the hardware between the AC86U Pro and the AX6000 is identical (the AX86U Pro has the 4th antenna inside instead of outside, but there's still 4 antennas). I mean, you could be ridiculous and say even if the difference is $10,000 the AX6000 is the "better" model for having the extra 2.5Gbit WAN port, but I hardly think you would argue that port is "worth" $10,000. So yes, use case is relevant because "worth" is relative. The extra port is worthless to me, it has zero worth. In fact, the aesthetics of the AX86U Pro are "worth" probably $30 to me. I'd probably pay $30 more for an AX86U Pro over an AX6000 because to me, the AX6000 is fugly. If we had any cats I'd probably pay $50 more just to avoid having a warm flat place that would undoubtedly attract cats to sit on it.No, use case has nothing to do with it. Better hardware is objectively better. Even when the difference was $100 or more, the GT-AX6000 was still the better model. And your budget doesn't change the worth of the router either.
Nobody knows what the future may bring, but one thing is for sure, the model with the better hardware will still be worth more to a future owner (whether sold or given to them).
And why am I discounting your argument @cmkelley? Because your use case doesn't apply to the points made above.
If normal users replaced this equipment on an annual basis, I might agree with your logic. But the truth is that most keep working router until they need to upgrade again. And for most, that is years from now.
In that time frame, ISP speeds change, client devices change, and most importantly, our expectations of our equipment changes too. In that sense, spending $80 more today is trivial.
You're conflating extra features (a 2.5Gbit WAN port) with "worth", and the two aren't the same thing at all. A top of the line, tricked out Subaru WRX STi undoubtedly has better hardware than a stock Honda Civic and will have a much higher resale value, but that doesn't at all mean everyone should go out and buy a WRX STi. And if "better" is your only yardstick, why not recommend the AXE16000? Clearly that's "better" hardware, with dual 10Gig ports in addition to a 2.5Gbit WAN port. I mean, what's $600 (US, Amazon) over the life of a router?
If you just want to talk "better" hardware, then don't recommend consumer routers at all.
stock Honda Civic
Thread starter | Title | Forum | Replies | Date |
C | From AC86U to AX86U | ASUS AX Routers & Adapters (Wi-Fi 6/6e) | 4 | |
A | Update home network (changing AC86U and AC68U) | ASUS AX Routers & Adapters (Wi-Fi 6/6e) | 9 | |
M | RT-AC86U -> RT-AX86U Pro Review | ASUS AX Routers & Adapters (Wi-Fi 6/6e) | 21 |
Welcome To SNBForums
