does not work wifi
fleash2000
There is the latest firmware from merlin. My Device
RT-AC66U B1
The Lenovo a3300 tablet, when connected to the router after 10-15 minutes online, loses the network completely, the icon shows the presence of the wifi, but in fact the Internet is gone!
on the Lenovo A6010 phone the same problem.
for phones samsung s3 and Samsung Galaxy Grand Duos - no problem.
On the lenovo forum, it was recommended to change the region in the wifi settings. such a configuration did not find. Help me find.
p.s.
used to be a router TL-WDR3500 - TP-Link I throw off a photo of his settings
now connected via cable zyxel NBG-418N to ensure the wifi in the room. With it, connect all devices without problems. The router was sent to me earlier from America.
if necessary I will reset the zixel settings photo.
I apologize for my English
I need your help
You cannot change the region. It is fixed to the region where it was sold.
This is why you should not use a router that was manufactured for another region.
OK.
if I leave only RT-AC66U B1 - the tablet and phone do not fully work with wafaot from the asus and I constantly need to overload the tablet and phone that would be on the Internet.
how to solve a problem?
Sorry, that did not translate. Can you say it again please.
I switch off zyxel NBG-418N. But about Wi-Fi 66u products of Lenovo don't want to work.
10-15 minutes work the tablet on Wi-Fi and then the Internet vanishes. Reset of the tablet helps.
Are you sure you have loaded the correct firmware for your router? There are two different models, RT-AC66U and RT-AC66U_B1:
https://www.asus.com/ru/Networking/RTAC66U/
https://www.asus.com/ru/Networking/RT-AC66U-B1/
This is the label for the RT-AC66U_B1:
Load the router with factory firmware.
As far as I can tell, none of your devices support 802.11ac. So you may need to try different Wi-Fi settings, like disabling beamforming.
Try disabling the 5 GHz radio and see if devices behave ok on 2.4 GHz.
Are you sure the router was working properly in the U.S.? Maybe you purchased a defective router that someone wanted to get rid of.
I purchase Asus 66 u in my country. Zyxel was purchase in USA.
Thanks for the help. I'll check.
As much as I would lime to recommend Merlins firmware, on my AC66U_B1 i get the best performance with the Asus firmware. Just disabled airtime fairness.
Also set the 2.4 band to a fixed channel at 20mhz and the 5 band to a fixed channel.
Should add that I tried Merlin 380.68 again today and could not get into system settings. Kept asking to change the user and password. Gave up after four factory resets and went back to latest Asus firmware.
Sent from my P01M using Tapatalk
Did you clear your browser cache? Or try a different browser?
Yes, three and two computers and a tablet.
