Double writing in syslog?
bayern1975
hello, i do not know how to solve double writing in syslog? scripts are checked more times....didn`t find any mistake....is possible something in these scripts that they runing double? using privacy-filter, iblocklist and Ipset-block scripts....with all them have duoble writing.....i use ab-solution with pixelserv too and here are all ok...here is log after reboot:
Apr 30 16:38:42 system: Privacy Filter (ipv4) loaded 117 unique ip addresses that will be rejected from contacting your router.
Apr 30 16:38:42 Firewall: iblocklist-loader.sh: Started processing BluetackSpider blocklist
Apr 30 16:38:42 Firewall: iblocklist-loader.sh: Loaded BluetackSpiderSingle blocklist with 68 entries
Apr 30 16:38:42 Firewall: iblocklist-loader.sh: Loaded BluetackSpiderCIDR blocklist with 683 entries
Apr 30 16:38:43 Firewall: iblocklist-loader.sh: Started processing BluetackDshield blocklist
Apr 30 16:38:43 Firewall: iblocklist-loader.sh: Loaded BluetackDshieldSingle blocklist with 1 entries
Apr 30 16:38:43 Firewall: iblocklist-loader.sh: Loaded BluetackDshieldCIDR blocklist with 1 entries
Apr 30 16:38:43 Firewall: iblocklist-loader.sh: Started processing BluetackWebexploit blocklist
Apr 30 16:38:43 Firewall: iblocklist-loader.sh: Loaded BluetackWebexploitSingle blocklist with 1459 entries
Apr 30 16:38:44 Firewall: iblocklist-loader.sh: Loaded BluetackWebexploitSingle blocklist with 1459 entries
Apr 30 16:38:44 Firewall: iblocklist-loader.sh: Loaded BluetackWebexploitCIDR blocklist with 39 entries
Apr 30 16:38:44 Firewall: iblocklist-loader.sh: Started processing BluetackProxy blocklist
Apr 30 16:38:45 Firewall: iblocklist-loader.sh: Loaded BluetackProxySingle blocklist with 5818 entries
Apr 30 16:38:45 Firewall: iblocklist-loader.sh: Loaded BluetackProxyCIDR blocklist with 1 entries
Apr 30 16:38:45 Firewall: iblocklist-loader.sh: Started processing BluetackMicrosoft blocklist
Apr 30 16:38:45 Firewall: iblocklist-loader.sh: Loaded BluetackMicrosoftSingle blocklist with 18 entries
Apr 30 16:38:45 Firewall: iblocklist-loader.sh: Loaded BluetackMicrosoftCIDR blocklist with 905 entries
Apr 30 16:38:46 Firewall: iblocklist-loader.sh: Loaded BluetackMicrosoftCIDR blocklist with 905 entries
Apr 30 16:38:46 (IPSET_Block.sh): 2882 v3.04 © 2016-2017 Martineau, Dynamic IPSET Blacklist banning request.....
Apr 30 16:38:46 (IPSET_Block.sh): 2890 v3.04 © 2016-2017 Martineau, Dynamic IPSET Blacklist banning request.....
Apr 30 16:38:46 (IPSET_Block.sh): 2890 IPSETs: 'Blacklist/Whitelist' created EMPTY..... [init nolog]
Apr 30 16:38:46 (IPSET_Block.sh): 2882 IPSETs: 'Blacklist/Whitelist' created EMPTY..... [init nolog]
Apr 30 16:38:46 (IPSET_Block.sh): 2882 Dynamic IPSET Blacklist banning enabled.
Apr 30 16:38:46 (IPSET_Block.sh): 2890 Dynamic IPSET Blacklist banning enabled.
Apr 30 16:38:46 (IPSET_Block.sh): 2890 Summary Blacklist: 28 0 Successful blocks! ( 5 IPs currently banned - 0 added )
Apr 30 16:38:46 (IPSET_Block.sh): 2882 Summary Blacklist: 28 0 Successful blocks! ( 5 IPs currently banned - 0 added )
I think you have 2 copies of your script running! This can happen if using the wan-up or firewall scripts, often the wan is brought up to run dhcp then it is taken down, brought up again when ISP details. Your script should check for multiple occurrences.
yes, I use wan-start created from ab-solution for runing entware with pixelserv and also firewall-start script for another two scripts...what should I do?
Poslano z mojega EVA-L09 z uporabo Tapatalk
I have a ping script linked from the wan-start, this runs forever so should the wan get restarted I would get multiple copies. I avoid this by always killing existing copes before starting using:-
killall wan_check.sh
/mnt/usb4gb/wan_check.sh &
