I installed the download master on my AC56U. I have a 1TB external HDD formatted to NTFS hooked up to the USB port. I added an ubuntu torrent file to see if it works. It just stays at 0% and never starts really. The system log file shows this:
May 4 23:32:40 transmission-daemon[2122]: Transmission 2.82 (14160) started (session.c:744)
May 4 23:32:40 transmission-daemon[2122]: RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
May 4 23:32:40 transmission-daemon[2122]: RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:828)
May 4 23:32:40 transmission-daemon[2122]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1035)
May 4 23:32:40 transmission-daemon[2122]: RPC Server Whitelist enabled (rpc-server.c:1039)
May 4 23:32:40 transmission-daemon[2122]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
May 4 23:32:40 transmission-daemon[2122]: UDP Failed to set receive buffer: requested 4194304, got 241664 (tr-udp.c:78)
May 4 23:32:40 transmission-daemon[2122]: UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
May 4 23:32:40 transmission-daemon[2122]: UDP Failed to set send buffer: requested 1048576, got 241664 (tr-udp.c:89)
May 4 23:32:40 transmission-daemon[2122]: UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
May 4 23:32:40 transmission-daemon[2122]: DHT Generating new id (tr-dht.c:310)
May 4 23:32:40 transmission-daemon[2122]: Using settings from "/tmp/mnt/External/Download2/config" (daemon.c:697)
May 4 23:32:40 transmission-daemon[2122]: Saved "/tmp/mnt/External/Download2/config/settings.json" (variant.c:1217)
May 4 23:32:40 transmission-daemon[2122]: Loaded 1 torrents (session.c:2007)
May 4 23:32:40 transmission-daemon[2122]: Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
May 4 23:32:40 transmission-daemon[2122]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
Why does it give me all of those errors? What is with the failed to initialize port 51413 stuff? I tried changing ports to 51412 but it still shows 51413 in the log file? It also won't let me delete torrents from the GUI it says "Failed to delete the task."
I also tried deleting the Download2 and asusware folders off the HDD and re-installing downloadmaster, nothing works.
I tried the Asus .5656 firmware and now I am on the merlin .41 firmware. Neither works.
