prom3theu5
Happy Holidays all!
move a strange issue I can’t work out.
happens on both official and Merlin on an Ax56u
Basically I have the 56u as the main router with an external unmanaged switch connected to port 2 (Netgear Gs108)
i then have a cat7 cable that runs through the floor boards downstairs with another gs108 connected to it
in that I have a bunch of devices, the tv, games console and Phillips hue bridge etc. Also have an eero 6 pro plugged i to that in bridge mode with one other eero on the network managed by this device. It is in bridge mode with no dhcp server running in it. The only DHCP server is the ASUS
now the problem. Every night about 3am the ASUS drops the Ethernet connection to the first external switch. I can see in the logs LINk Down on eth3 then a few seconds later link up at 1gbps however the router doesn’t display that the port is active and I have to unplug the cable and plug it back in every morning.
This means that the eeros all drop connection and my heating and everything goes offline in the middle of the night every day. All the wired devices also go offline. But the wifi on the ASUS works fine still as does other Ethernet sockets in it. I’ve tried changing socket. No difference issue just moves to new socket
currently on latest Merlin firmware. Can’t figure out what’s happening here.
I have spanning tree protocol enabled and jumbo frames disabled on the ASUS
I’ve also tried swapping the switches (GS108) for others I have
any suggestions would be greatly appreciated. Thanks
