Hello,
First excuse me for mistakes, I'm french, I will do my best ^^.
I have a lot errors log on my router.
Router: RT-AC68U
Firmware Merlin: 380.58
System log:
My modem (Billion 7800DXL) is bridge with the RT-AC68U.
On this modem, I use SNMP and I don't see connection problem with cacti; on the web interface of the modem, I can see:
The download/upload rate are ok and don't change since 97 days, so I don't think it's a problem with the modem or my ADSL line.
Can you help me to understand why the router is disconnected many times in a day (40 times / day in the system log) ? Is this a firmware problem or other idea/suggestion ?
Also, I've tried to ping my router:
At last, less important, I have this log every 3-4 seconds:
Thank you for your help.
Router: RT-AC68U
System log:
May 4 12:26:35 pppd[16886]: Serial link appears to be disconnected.
May 4 12:26:35 pppd[16886]: Connection terminated.
May 4 12:26:36 WAN Connection: Fail to connect with some issues.
May 4 12:26:36 stop_nat_rules: apply the redirect_rules!
May 4 12:26:45 kernel: br0: received packet on vlan1 with own address as source address
May 4 12:26:46 pppd[16886]: Connected to xx:xx:xx:xx:xx:xx via interface eth0
May 4 12:26:46 pppd[16886]: Connect: ppp0 <--> eth0
May 4 12:26:46 pppd[16886]: CHAP authentication succeeded
May 4 12:26:46 pppd[16886]: peer from calling number xx:xx:xx:xx:xx:xx authorized
May 4 12:26:47 pppd[16886]: local IP address xxx.xxx.xxx.xxx
May 4 12:26:47 pppd[16886]: remote IP address xxx.xxx.xxx.xxx
May 4 12:26:47 rc_service: ip-up 23677:notify_rc start_firewall
May 4 12:26:47 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
May 4 12:26:48 wan: finish adding multi routes
May 4 12:26:48 rc_service: ip-up 23677:notify_rc stop_upnp
May 4 12:26:48 rc_service: waitting "start_firewall" via ip-up ...
May 4 12:26:48 kernel: br0: received packet on vlan1 with own address as source address
May 4 12:26:49 rc_service: ip-up 23677:notify_rc start_upnp
May 4 12:26:49 rc_service: waitting "stop_upnp" via ip-up ...
May 4 12:26:51 kernel: br0: received packet on vlan1 with own address as source address
May 4 12:26:52 WAN Connection: WAN was restored.
May 4 12:26:54 rc_service: ip-up 23677:notify_rc start_firewall
May 4 12:26:56 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
System Up-Time 97D 22H 25M 47S
Mode ADSL_G.dmt
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 14.8 18.0
Attenuation (dB) 39.0 21.5
Output Power (dBm) 19.8 12.3
Attainable Rate (Kbps) 7156 1208
Rate (Kbps) 6112 800
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
ping -t 192.168.0.1
Envoi d'une requête 'Ping' 192.168.0.1 avec 32 octets de données :
Réponse de 192.168.0.1 : octets=32 temps<1ms TTL=64
Délai d'attente de la demande dépassé.
Statistiques Ping pour 192.168.0.1:
Paquets : envoyés = 26, reçus = 24, perdus = 2 (perte 7%),
Durée approximative des boucles en millisecondes :
Minimum = 0ms, Maximum = 0ms, Moyenne = 0ms
