Solved How to access my ONT from router
OK that's progress. Try adding this:
iptables -t nat -I POSTROUTING -o eth0:0 -j MASQUERADE
nothing so far
192.168.100.1 is still pingable from router but not from pc connected to router.
C:\Users\andresmorago>tracert -w 100 -d 192.168.100.1
Tracing route to 192.168.100.1 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  10.0.4.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
C:\Users\andresmorago>ping 192.168.100.1
Pinging 192.168.100.1 with 32 bytes of data:
Request timed out.
Request timed out.
Ping statistics for 192.168.100.1:
    Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
Disable the VPN client just in case that is effecting things.
EDIT: Also, try seeing if this has an effect:
iptables -t nat -I POSTROUTING -o eth0 -j MASQUERADE
nothing :(
i have disabled both vpn server and client.
no access from lan clients.
router side looks ok
andresmorago@bga01:/tmp/home/root# netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
191.110.192.1   0.0.0.0         255.255.255.255 UH        0 0          0 ppp0
192.168.100.0   0.0.0.0         255.255.255.0   U         0 0          0 eth0
10.0.4.0        0.0.0.0         255.255.255.0   U         0 0          0 br0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 vlan100
10.0.0.0        0.0.0.0         255.0.0.0       U         0 0          0 br0
127.0.0.0       0.0.0.0         255.0.0.0       U         0 0          0 lo
0.0.0.0         191.110.192.1   0.0.0.0         UG        0 0          0 ppp0
andresmorago@bga01:/tmp/home/root# ping 192.168.100.1
PING 192.168.100.1 (192.168.100.1): 56 data bytes
64 bytes from 192.168.100.1: seq=0 ttl=64 time=1.775 ms
64 bytes from 192.168.100.1: seq=1 ttl=64 time=1.461 ms
64 bytes from 192.168.100.1: seq=2 ttl=64 time=1.341 ms
^C
--- 192.168.100.1 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 1.341/1.525/1.775 ms
andresmorago@bga01:/tmp/home/root# ifconfig -a
br0       Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          inet addr:10.0.4.1  Bcast:10.0.4.255  Mask:255.255.255.0
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:1743942 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3893611 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1214977107 (1.1 GiB)  TX bytes:4977065228 (4.6 GiB)
br0:pixelserv-t Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          inet addr:10.0.4.2  Bcast:10.255.255.255  Mask:255.0.0.0
dpsta     Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0      Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:4488417 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2336082 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1296045148 (1.2 GiB)  TX bytes:1941617998 (1.8 GiB)
          Interrupt:179 Base address:0x4000
eth0:0    Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          inet addr:192.168.100.2  Bcast:192.168.100.255  Mask:255.255.255.0
eth1      Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          RX packets:59072 errors:0 dropped:0 overruns:0 frame:1544954
          TX packets:80280 errors:16 dropped:0 overruns:0 carrier:0
          RX bytes:12170581 (11.6 MiB)  TX bytes:14749352 (14.0 MiB)
          Interrupt:163
eth2      Link encap:Ethernet  HWaddr 88:D7:F6:88:53:5C
          RX packets:1353077 errors:0 dropped:0 overruns:0 frame:931022
          TX packets:2131352 errors:702 dropped:0 overruns:0 carrier:0
          RX bytes:1126703476 (1.0 GiB)  TX bytes:464383677 (442.8 MiB)
          Interrupt:169
ifb0      Link encap:Ethernet  HWaddr 4A:4F:E1:0C:4A:93
          BROADCAST NOARP  MTU:1500  Metric:1
          collisions:0 txqueuelen:32
ifb1      Link encap:Ethernet  HWaddr 92:13:C0:29:78:49
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
          RX packets:192427 errors:0 dropped:0 overruns:0 frame:0
          TX packets:192427 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:44803605 (42.7 MiB)  TX bytes:44803605 (42.7 MiB)
lo:0      Link encap:Local Loopback
          inet addr:127.0.1.1  Mask:255.0.0.0
ppp0      Link encap:Point-to-Point Protocol
          inet addr:167.0.62.103  P-t-P:191.110.192.1  Mask:255.255.255.255
          UP POINTOPOINT RUNNING MULTICAST  MTU:1480  Metric:1
          RX packets:3408119 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1602339 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4225479337 (3.9 GiB)  TX bytes:1341809848 (1.2 GiB)
vlan1     Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          RX packets:269827 errors:0 dropped:0 overruns:0 frame:0
          TX packets:411352 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:123881728 (118.1 MiB)  TX bytes:343265281 (327.3 MiB)
vlan100   Link encap:Ethernet  HWaddr 88:D7:F6:88:53:58
          inet addr:169.254.188.203  Bcast:169.254.255.255  Mask:255.255.0.0
          RX packets:4215476 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1924638 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5386065025 (5.0 GiB)  TX bytes:1598348282 (1.4 GiB)
@ColinTaylor
This last command you mentioned did it! :) Im now able to access ONT 192.168.100.1
so i guess we dont need eth0:0 but eth0
VPN client and server are stable also
That's good news. I had also been thinking that you probably don't need to create an eth0:0 interface at all. But rather just reuse eth0 by assigning an IP address to it:
ifconfig eth0 192.168.100.2 netmask 255.255.255.0
Whether one way or the other is "better" is probably a matter of opinion.
great idea. will try that as well
so in conclusion:
thanks to all for the help!
Hi! What an intereseting thread!
I also have a ONT bridged to my 87U and its a real pit* to unplug/plug my pc from router to ONT every time I need access to it.
It would be awesome if I could access it directly from my LAN.
I've tried to understand what was written here to addapt it to my particular case but its beyond my humble understanding.
Please, could you point me to the correct lines in order to make it work for my setup?
I paste here the outputs that were asked to OP:
ASUSWRT-Merlin RT-AC87U 384.13_10 Sun Jun 28 17:57:25 UTC 2020
@ASUS_RT-AC87U:/tmp/home/root# nvram get wan0_ifname
vlan2
@ASUS_RT-AC87U:/tmp/home/root# netstat -rn
181.117.205.1   0.0.0.0         255.255.255.255 UH        0 0          0 vlan2
169.254.39.0    0.0.0.0         255.255.255.0   U         0 0          0 br0
192.168.0.0     0.0.0.0         255.255.255.0   U         0 0          0 br0
181.117.205.0   0.0.0.0         255.255.255.0   U         0 0          0 vlan2
0.0.0.0         181.117.205.1   0.0.0.0         UG        0 0          0 vlan2
@ASUS_RT-AC87U:/tmp/home/root# ifconfig -a
aux0      Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          RX packets:209520 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:16667465 (15.8 MiB)  TX bytes:0 (0.0 B)
          Interrupt:180 Base address:0x5000
br0       Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          inet addr:192.168.0.1  Bcast:192.168.0.255  Mask:255.255.255.0
          RX packets:5204244 errors:0 dropped:0 overruns:0 frame:0
          TX packets:16209066 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13063775736 (12.1 GiB)  TX bytes:19306288783 (17.9 GiB)
br0:0     Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          inet addr:169.254.39.99  Bcast:169.254.39.255  Mask:255.255.255.0
eth0      Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          RX packets:25778224 errors:0 dropped:0 overruns:0 frame:0
          TX packets:21652117 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:162776873 (155.2 MiB)  TX bytes:24925956 (23.7 MiB)
          Interrupt:181 Base address:0x6000
eth1      Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          RX packets:159676 errors:0 dropped:0 overruns:0 frame:453684
          TX packets:2614365 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:22203576 (21.1 MiB)  TX bytes:722160409 (688.7 MiB)
          Interrupt:163
ifb0      Link encap:Ethernet  HWaddr BA:B7:84:8F:DB:03
ifb1      Link encap:Ethernet  HWaddr 66:BF:61:CE:39:33
          RX packets:370351 errors:0 dropped:0 overruns:0 frame:0
          TX packets:370351 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:49775759 (47.4 MiB)  TX bytes:49775759 (47.4 MiB)
vlan1     Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          RX packets:14359652 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17606171 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13594698756 (12.6 GiB)  TX bytes:20975511930 (19.5 GiB)
vlan2     Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C8
          inet addr:181.117.205.20  Bcast:181.117.205.255  Mask:255.255.255.0
          RX packets:11628088 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4211943 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:11825618676 (11.0 GiB)  TX bytes:435273373 (415.1 MiB)
wl0.1     Link encap:Ethernet  HWaddr D0:17:C2:B3:39:C9
          RX packets:74810 errors:0 dropped:0 overruns:0 frame:453684
          TX packets:1895548 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:14608225 (13.9 MiB)  TX bytes:758479293 (723.3 MiB)
THANKS in advance for your help!!!
To start with, what is the address of your bride device.
I am not familiar with the 87U, but I would hazard from your posting that you will need to assign an address to eth0 that is in the same subnet as your bridge device. Reference post 27
Are you using ppoe or something similar for your connection?
FOA thanks for your reply Jeffrey!
What is the address of your bride device.
Where can i get that info?
I'm using "Automatic IP" under Wan Connection type (Enable Wan and Enable Nat both to yes)
When you connect to your ONT device, what address do you use? Or what name? Assuming you are using a web browser
The master beat me to it. Sorry for the double post.
Thanks @ColinTaylor and @Jeffrey Young , and excuse my fo*lness...
The address I use when I'm connected directly to ONT is 192.168.100.1
Thanks!
And to make sure of no subnet conflicts, what is your address of your 87U?
It's 192.168.0.1 (subnet 255.255.255.0)
Ok, using the "in conclusion" part of Colin's post in post 27 above, those two commands should also work for you as well.
SSH into your 87U and type each one in. Then see if can ping the ONT from the 87U and from a command prompt on your computer.
Using those commands may or may not work. But I wouldn't recommend using them because if he disabled hardware acceleration there would be conflicting IP addresses being assigned to the WAN interface.
As this is not a pppoe setup he should try using the "usual" solution to this problem. It has the advantage that you shouldn't need the iptables rule because that already exists. So it's just:
ifconfig $(nvram get wan0_ifname):0 192.168.100.2 netmask 255.255.255.0
Thanks to both once again! top notch support and kindness!
Tonight when I get home I'll try Colin's approach to avoid any of the issues he stated (I'm using CTF + FA if it counts).
Just to win some time: if it works I do have to add it to wan-start script to make it permanent, don't I?
And to undone changes just delete that line from script and reboot, right?
Will report back with results!
THANKS!
I certainly bow to Colin's wisdom on this one. Colin, by far, goes out of his way to help anybody. I certainly respect his knowledge and willingness to help. I'd listen to him.
If the wan0_ifname value does not work, try the eth0.
