Perhaps the problem then is the occasional reboot? For some people it happens more often than for others, so they experience wifi-drops all the time (while in fact the entire router is rebooting). And the DHCP-messages, although they shouldn't be there, are just harmless and unrelated?
I having the same issues also 374.40 which coming always from my HP Laptop. Ant it looks like only affecting this Laptop which has a Intel N card inside. But by me its only happening running Windows 7... When running my Gentoo I don't see this, so It probably isn't the Hardware itself.
Make sure you have an up-to-date driver from Intel's site (not from HP).
Delete and recreate the wireless connection on the laptop to flush out any outdated lowlevel settings associated to it.
I dont think its driver related as my Nvidia Shield can cause a restart (both ssid's go down and then come back up a few minutes later) to happen during gamestreaming. Hard to replicate it though. Sometimes it works fine for extended play, others not so much.
I was replying to Speedy1205's issue, which is not necessarily the same.
Apr 15 19:54:34 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 19:54:34 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 19:56:20 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 19:56:20 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:06:11 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:06:11 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:08:28 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:08:28 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:08:59 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:08:59 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:10:53 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.194 88:cb:87:f1:c1:07
Apr 15 20:10:53 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.194 88:cb:87:f1:c1:07 Christinas-iPad
Apr 15 20:18:44 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.194 88:cb:87:f1:c1:07
Apr 15 20:18:44 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.194 88:cb:87:f1:c1:07 Christinas-iPad
Apr 15 20:20:51 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:20:51 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:23:28 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:23:28 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:32:11 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:32:11 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
Apr 15 20:38:27 dnsmasq-dhcp[2164]: DHCPREQUEST(br0) 192.168.1.77 d0:23:db:1f:3f:92
Apr 15 20:38:27 dnsmasq-dhcp[2164]: DHCPACK(br0) 192.168.1.77 d0:23:db:1f:3f:92 Mycroft
I am seeing the DHCP requests filling up my log, too. It solely happens with Apple products connected via 2.4 GHz
Running N66U with 374.41 beta1
rrrrrrrr - Do you also have inconsistent wifi connectivity as well? Does this happen with laptop/iMacs or just iOS devices on 2.4GHz?
For me my macbook and any wired devices are fine, but iPhones are not. Signal strength is fine on the phones at -66dBm.
Interestingly, the iPad on 5GHz is fine. No dropped connections and no DHCPREQUEST entries in the log. Also, when I switch the iPad over to the 2.4GHz I do not get dropped wifi and no multiple DHCPREQUEST entries; just one for the original association with the SSID. It doesn't seem to the the iOS version, just something strange with the iPhones.
I have a feeling this has something to-do with iPhone's switching between 3G/Wifi when locking/unlocking the device. Haven't been able to reproduce it on my end though. In iOS setting try reset network information and see if the issue persists.
Apr 16 11:30:12 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 11:30:12 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 11:55:24 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 11:55:24 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 12:02:12 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:02:12 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 12:02:16 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:02:16 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 12:02:17 dnsmasq-dhcp[507]: DHCPDISCOVER(br0) 4c:21:d0:6c:63:dc
Apr 16 12:02:17 dnsmasq-dhcp[507]: DHCPOFFER(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:02:17 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:02:17 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 12:06:12 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:06:12 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 12:07:42 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:07:42 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
Apr 16 12:14:04 dnsmasq-dhcp[507]: DHCPREQUEST(br0) 192.168.1.132 4c:21:d0:6c:63:dc
Apr 16 12:14:04 dnsmasq-dhcp[507]: DHCPACK(br0) 192.168.1.132 4c:21:d0:6c:63:dc android-e44a95c0ca7b7c43
I'm not so sure about this. I have the constant DHCP chatter with a Sony Xperia Android tablet which is sitting idle. The tablet is WiFi only, no 3G.
My general response to this is to give all my devices static (not reserved DHCP) LAN addresses. I guess I will do the same with this Android tablet.
I'm not so sure about this. I have the constant DHCP chatter with a Sony Xperia Android tablet which is sitting idle. The tablet is WiFi only, no 3G....
Well, I've managed to fix the wifi connection dropping issue, although I took the shotgun approach so I'm not sure the specific fix, or if all steps were necessary.
Along with upgrading to 374.41, I reset both phones' network settings and cleared the router's nvram and rebuilt the settings from scratch. This seems to have fixed connectivity which is much more stable than before.
The DHCP requests are still filling up the system log, so that is an unrelated issue to the connectivity. In any event, I'm glad to have a stable connection on the phones again.
I have a ton to rebuild from scratch.
What are the thoughts if I save my settings, do a factory reset, then upload my settings?
Any chance of that fixing things?
Welcome To SNBForums
