I am Italian, but I used to live in Finland.Just courious - where did you come from (NL?) to your new home?
Hey folks and greetings from Germany (yes I moved to a new country)!!!
I have finally got some time to work on the DSL-AC68U and here we go.. there is a fresh new pre-release looking for testers.
Since we got new blobs from ASUS, I think we can get a stable version this time, and it will be based on 384.14
So please help me in testing the new firmware: https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/384.14-beta1-gnuton2
I will run the update over this weekend and report back early next week.
Grazie molto.
Nov 23 05:38:09 DSL-AC68U-5598 acsd: scan in progress ...
Nov 23 05:38:09 DSL-AC68U-5598 acsd: selected channel spec: 0x100b (11)
Nov 23 05:38:09 DSL-AC68U-5598 acsd: Adjusted channel spec: 0x100b (11)
Nov 23 05:38:09 DSL-AC68U-5598 acsd: acs_set_chspec: 0x100b (11) for reason APCS_CSTIMER
@GNUton - just 1 issues so far - which no amount of reboots have solved ...
Code:Nov 23 05:38:09 DSL-AC68U-5598 acsd: scan in progress ... Nov 23 05:38:09 DSL-AC68U-5598 acsd: selected channel spec: 0x100b (11) Nov 23 05:38:09 DSL-AC68U-5598 acsd: Adjusted channel spec: 0x100b (11) Nov 23 05:38:09 DSL-AC68U-5598 acsd: selected channel spec: 0x100b (11) Nov 23 05:38:09 DSL-AC68U-5598 acsd: acs_set_chspec: 0x100b (11) for reason APCS_CSTIMER
The above message keeps presenting in the system log - over and over again.
Otherwise - everything running well - including built in ntp server / amtm / Diversion - pixelserv / Skynet and Scribe. I believe "Let's Encrypt" is still broken in the Asus Stock release - but will be fixed in the next Asus code release.
Cool thanks very much folks!
As for the DoT for WAN there is a feature request https://github.com/gnuton/asuswrt-merlin.ng/issues/17 , but I do not have time to work on it, so if anyone wanna jump in and get it implemented you're welcome!![]()
It's a new feature only if you set the DSL as WAN, since DSL is not available in upstream merlin.Not a coder - so well beyond my abilities - but that said, I'm puzzled because the DoT feature requested is part and parcel of the Merlin code you are basing your release on ??? This is not a "new" feature - but rather one which has been part of Merlin-Ware since 384.12, through 384.13 and now in 384.14-alpha /beta /beta2 ??
The DSL page is different from the regular WAN page, so implementing DNS Privacy isn't just a matter of toggling the switch to on at build time, it has to be manually merged into the DSL WAN page.
New pre-release: 384.14_beta2-gnuton0_alpha2 available.
This is based on the merlin beta2.
For people willing to test builds, please test this.
Thanks a lot!
Welcome To SNBForums
