dukehole66
I cannot wait if there is a proper build for the DSL AC87VG DSL modem.
With a stable firmware with all the features.
There isn'tI cannot wait if there is a proper build for the DSL AC87VG DSL modem.
where do u see cpu temprature ?should be about the same as RT-AC68U, 90°C is too much for durable proper work.
cant remember, dont have it anymore and different with stock or Merlin and depending on firmware version.where do u see cpu temprature ?
dont replace it with thermal paste - its too much space between), you could use additional thermal paste to close gap.I've tried replacing the thermal pads with thermal paste
are you able to repair such things (done similar in the past)?
If yes and you want to use this router longer than next 1 or 2 years spend an hour and improve thermal contact.
Otherwise let it be or put a small 5V USB fan behind.
mine is 86C - cpu ?
what shall i do ?
I see your point ,but in the country i live this device is expensive and I do not have technical knowledge to fix.The SoC's that these routers are built on are different than our experiences with other computer devices.
I have seen many routers with the same temps, including my routers, with no ill effects for many years.
Stock firmware or RMerlin's forks make no difference, btw.
While you don't want the temperature to be too high, if it stays in the 80'sC then I wouldn't be too worried myself.
If you have a small USB fan or a laptop cooler to use, it won't hurt either.![]()
an external fan would be noisy and buggy as it is staying beside the TV.
there was no jffs scrits, entware or optware installed, even qos and bandwith managment and statictis options were disabled. it should not be hot as my config is too basic.
where do i check the temprature on the official firmware ? I will check and compare with the official buid, if this is working on around same tempratures then i will think this is normal and install custom firmware again.
Yup, that's why i've ordered some new thermal pads. Hope they will work.dont replace it with thermal paste - its too much space between)
there wont be any difference between stock and Merlin based firmwares, CPU clock and usage will be about the same and so temps too.I will turn back to official firmware and see the temprature change. maybe this is because custom firmware
Thanks. I can confirm that the device list and qos page are working just fine.Hi there,
I have just published a pre-release. https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/384.11-gnuton2-alpha1 which should fix several issues in the webui.
The fixed issues are listed here: https://github.com/gnuton/asuswrt-merlin.ng/issues
Note: the firmware has not been tested at all yet. I will do ASA I get home...
Welcome To SNBForums
