Reading this threads posts, especially the first, makes me cringe at any solution short of involving the ISP's and a 'pro' or two (ideally, one for each business. To ensure that each business stays private and protected against the other).
This is a bad idea and does not bode well no matter what hardware and associated rules setup is used.
The second ISP for each business is expensive over time, but if that is truly what is needed, then the cost is just part of doing that business.
Sharing the WAN connections when both require remote access to each business' isn't something I would do with a close relative, let alone a neighbor with access provided to additional strangers too.
If you need internet connectivity and a secure network 100%, then this is a bad idea from step one.
I think this is an exercise in networking knowledge. They are only backing up each other and not sharing LAN networks. There is exposure when running through the other persons router in that the local router owner can log or modify all internet traffic.
When each needs to get access to their networked equipment through their respective ISP's, they are sharing WAN's which means they will get access to the LAN too (or at least to specific devices).
If this is simply an exercise, call up your ISP and ask for a second WAN address (for a month, or until the knowledge is secured).
I understand the concern of being able to interfere with the other's LAN when sharing a WAN (which would happen only in case of failure of my own ISP).
The idea to ask my ISP for a second WAN address for a month may work where you live, but not in Panama.
Contracts have to be made for at least a year, no exceptions. The ISPs (in my area there are only two available) are not responsive to special requests and the only time I have been able to talk to one of their technicians (it was about port forwarding), I found out that I knew more than him and he gave me wrong and useless answers.
On the long run a second WAN address from the same ISP would of course be useless because when WAN1 fails, also WAN2 would fail.
I am trying to resolve as many questions on paper as possible before buying costly equipment or making new contracts with ISPs. I think this is how it should be done, not experimenting without sufficient previous knowledge. As I said, I am willing to study, but of course I cannot pass my next 3 years studying networking, just to resolve this single problem. So friendly voluntary help is appreciated.
If they use separate networks for their LANs there will not be any sharing of the LAN unless you create static routes and create routing between LANs whether real networks or VLANs. The only thing they are sharing is the default gateway or default route. You need a default route which fails over to a second default route in case of failure. I guess a kind of default gateway of last resort.
That is not what is suggested or required. If my neighbor shares their WAN with me which I could enable and disable at will, I could conceivably connect to their LAN at my leisure. And they to mine.
This is past the default gateway mode. It is a physical connection to their network (through their WAN / router).
| Thread starter | Title | Forum | Replies | Date |
| T | When running a router as a switch can the WAN port work as 5th LAN port? | Routers | 4 | |
| G | No WAN with Bell 4000 passthrough | Routers | 10 | |
| U | Want to move away from Asus routers, Ubiquiti? advice needed | Routers | 134 |
Welcome To SNBForums
