WANFailover Dual WAN Failover Script
WAN0TARGET="$(nvram get wan0_dns | awk '{print $1}')"
WAN1TARGET="$(nvram get wan1_gateway)"
My wife is using internet.. When I can ill do a sh +x, and kill my primary line see if I can see something.
Send your script over and let me take a look, somewhere it is trying to grep but doesn’t have a parameter set like -e? Perhaps the script status check at the top?
If you run diff, youll see nothings really been changed.
I’m not home atm, run diff and send me the output please.
admin@RT-AX86U-D7D0:/jffs/scripts# diff original wan2
--- original
+++ wan2
@@ -1,4 +1,4 @@
-#!/bin/sh
+#!/bin/sh
# Author: Ranger802004
# Version 1.1
@@ -32,7 +32,7 @@
DNSRESOLVFILE="/tmp/resolv.conf"
#Ping Target for failure detections, must be routed over targeted interface
-WAN0TARGET="$(nvram get wan0_dns1_x)"
+WAN0TARGET="$(nvram get wan0_dns | awk '{print $1}')"
#Ping count before WAN is considered down, requires 100% Packet Loss.
@@ -45,11 +45,11 @@
#QoS Manual Settings Variables
#QoS Inbound Bandwidth - Values are in Kbps
-WAN0_QOS_IBW=972800
-WAN1_QOS_IBW=97280
+WAN0_QOS_IBW=2972800
+WAN1_QOS_IBW=2297280
#QoS Outbound Bandwidth - Values are in Kbps
-WAN0_QOS_OBW=972800
-WAN1_QOS_OBW=5120
+WAN0_QOS_OBW=22972800
+WAN1_QOS_OBW=225120
#QoS WAN Packet Overhead - Values are in Bytes
WAN0_QOS_OVERHEAD=42
WAN1_QOS_OVERHEAD=18
@@ -311,7 +311,7 @@
# Trigger WAN Event
wanevent ()
-/jffs/scripts/wan-event
+#/jffs/scripts/wan-event
wanstatus
scriptstatus
--- original
+++ wan2
@@ -1,4 +1,4 @@
-#!/bin/sh
+#!/bin/sh
# Version 1.1
@@ -32,7 +32,7 @@
@@ -45,11 +45,11 @@
-WAN1_QOS_IBW=97280
-WAN1_QOS_OBW=5120
@@ -311,7 +311,7 @@
# Trigger WAN Event
wanevent ()
wanstatus
scriptstatus
Did you change something with the ping count or timeout? Go ahead and run this command and send me the output.
nvram show | grep -e “wan”
You need wan1_dns populated, most likely.
Shouldn’t unless he is targeting it for his ping target. The switch wan will check that variable and then go to dns1_x and dns2_x variables. Unless both of those are blank as well should be fine.
@Ranger802004 and @dave14305 , right now I just have dual wan set in the UI, with nothing setup for ping,dns,etc while trying the script. Besides that ranger as you can see, i didnt change much at all in the script. I can give you the output of nvram if you tell me exactly what your looking for. wan1_dns points to the secondary modem ip right now. As does nvram get wan1_gateway
I’m just looking for if any of the variables used throughout the script are blank.
nvram show 2>/dev/null | grep -E "^wan[01]?_dns|^wan[01]?_ifname"
I’m just trying to understand your grep problem.
I only saw it when it switch to wan1, but I cannot test failover for now.
admin@RT-AX86U-D7D0:/jffs/scripts# nvram show 2>/dev/null | grep -E "^wan[01]?_dns|^wan[01]?_ifname"
wan0_dns=1.1.1.1 8.8.8.8
wan0_dns1_x=1.1.1.1
wan0_dns2_x=
wan0_dnsenable_x=1
wan0_ifname=eth0
wan1_dns=192.168.10.1
wan1_dns1_x=1.1.1.1
wan1_dns2_x=
wan1_dnsenable_x=1
wan1_ifname=eth5
wan_dns=192.168.10.1
wan_dns1_x=1.1.1.1
wan_dns2_x=
wan_dnsenable_x=1
wan_ifname=eth5
wan_ifnames=eth0 eth5
I sent the diff, i didnt touch any of that.
admin@RT-AX86U-D7D0:/jffs/scripts# nvram show | grep -e “wan”
size: 74666 bytes (56406 left)
wan0_dns1_x=1.1.1.1
wan0_dns2_x=
wan0_dnsenable_x=1
wan0_ifname=eth0
wan1_dns1_x=1.1.1.1
wan1_dns2_x=
wan1_dnsenable_x=1
wan1_ifname=eth5
wan_dns1_x=1.1.1.1
wan_dns2_x=
wan_dnsenable_x=1
wan_ifname=eth5
I have a clue on the problem and can test and add some logic for it later, do this in the meantime and test, assign a second DNS server to your WAN1 interface and see if gets rid of the error.
sorry but I assume, this will work for now?
admin@RT-AX86U-D7D0:/jffs/scripts# nvram set wan1_dns2_x=8.8.8.8
admin@RT-AX86U-D7D0:/jffs/scripts# nvram set wan0_dns2_x=8.8.8.8
There seems to be a misplaced/misused & in the middle of the until condition in switchwan().
Yea should work as a temp fix until I can update the script this weekend.
Is that what your seeing?
