Pak Kriss
OK. then I understood your script and readme correctly.1. No I don't monitor bandwidth.
2. You can set ping timeout to 1 second and 3000ms pings would be considered packet loss.
I thought I leverage the 1 second timeouts and max. ICMP package size.
Question: it's possible to define a packet loss amount? Percentage or amount or something similar, to define down state
Feature request: Switch from seconds to milliseconds scheme
