Sep 25 19:38:35 dropbear[770]: Child connection from 192.168.1.75:2570
Sep 25 19:38:35 dropbear[770]: Password auth succeeded for 'admin' from 192.168.1.75:2570
Sep 25 19:38:35 rc_service: service 772:notify_rc restart_wan
Sep 25 19:38:35 custom_script: Running /jffs/scripts/service-event (args: restart wan)
Sep 25 19:38:35 dropbear[770]: Exit (admin) from <192.168.1.75:2570>: Exited normally
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 0 stopping)
Sep 25 19:38:35 pppd[2232]: Hangup (SIGHUP)
Sep 25 19:38:35 pppd[2232]: Terminating on signal 15
Sep 25 19:38:35 pppd[2232]: Connect time 997.6 minutes.
Sep 25 19:38:35 pppd[2232]: Sent 1057791802 bytes, received 2022448675 bytes.
Sep 25 19:38:35 lldpd[1392]: removal request for address of xx.xxx.xxx.xx%20, but no knowledge of it
Sep 25 19:38:35 wsdd2[3822]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Sep 25 19:38:35 pppd[2232]: Connection terminated.
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 0 disconnected)
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 0 stopped)
Sep 25 19:38:35 pppd[2232]: Sent PADT
Sep 25 19:38:35 pppd[2232]: Exit.
Sep 25 19:38:35 wan-failover.sh: Debug - Script Mode: cron
Sep 25 19:38:35 wan-failover.sh: Debug - Function: cronjob
Sep 25 19:38:35 lldpd[1392]: removal request for address of 169.254.193.178%9, but no knowledge of it
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 1 stopping)
Sep 25 19:38:35 lldpd[1392]: removal request for address of 192.168.8.100%21, but no knowledge of it
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 1 disconnected)
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 1 stopped)
Sep 25 19:38:35 custom_script: Running /jffs/scripts/wan-event (args: 1 init)
Sep 25 19:38:36 wan-failover.sh: Debug - Script Mode: cron
Sep 25 19:38:36 wan-failover.sh: Debug - Function: cronjob
Sep 25 19:38:36 custom_script: Running /jffs/scripts/wan-event (args: 0 init)
Sep 25 19:38:36 custom_script: Running /jffs/scripts/wan-event (args: 0 connecting)
Sep 25 19:38:36 pppd[1057]: Plugin rp-pppoe.so loaded.
Sep 25 19:38:36 pppd[1057]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.7
Sep 25 19:38:36 pppd[1100]: pppd 2.4.7 started by admin, uid 0
Sep 25 19:38:36 pppd[1100]: PPP session is 8501 (0x2135)
Sep 25 19:38:36 pppd[1100]: Connected to 00:12:d9:68:99:19 via interface eth0
Sep 25 19:38:36 pppd[1100]: Using interface ppp0
Sep 25 19:38:36 pppd[1100]: Connect: ppp0 <--> eth0
Sep 25 19:38:36 custom_script: Running /jffs/scripts/service-event-end (args: restart wan)
Sep 25 19:38:37 pppd[1100]: PAP authentication succeeded
Sep 25 19:38:37 pppd[1100]: peer from calling number 00:12
9:68:99:19 authorized
Sep 25 19:38:37 lldpd[1392]: removal request for address of xx.xxx.xxx.xx%25, but no knowledge of it
Sep 25 19:38:37 wsdd2[3822]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Sep 25 19:38:37 pppd[1100]: local IP address xx.xxx.xxx.xx
Sep 25 19:38:37 pppd[1100]: remote IP address xx.xxx.xxx.xx
Sep 25 19:38:37 custom_script: Running /jffs/scripts/wan-event (args: 0 connected)
Sep 25 19:38:37 custom_script: Running /jffs/scripts/nat-start
Sep 25 19:38:37 wan-failover.sh: Debug - Script Mode: cron
Sep 25 19:38:37 wan-failover.sh: Debug - Function: cronjob
Sep 25 19:38:37 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 25 19:38:37 wan: finish adding multi routes
Sep 25 19:38:37 rc_service: ip-up 1128:notify_rc stop_samba
Sep 25 19:38:37 rc_service: ip-up 1128:notify_rc start_samba
Sep 25 19:38:37 rc_service: waitting "stop_samba" via ip-up ...
Sep 25 19:38:37 custom_script: Running /jffs/scripts/service-event (args: stop samba)
Sep 25 19:38:37 wsdd2[3822]: Terminated received.
Sep 25 19:38:37 wsdd2[3822]: terminating.
Sep 25 19:38:37 Samba_Server: smb daemon is stopped
Sep 25 19:38:37 custom_script: Running /jffs/scripts/service-event-end (args: stop samba)
Sep 25 19:38:38 custom_script: Running /jffs/scripts/service-event (args: start samba)
Sep 25 19:38:39 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
Sep 25 19:38:39 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Sep 25 19:38:40 Diversion: restarted Dnsmasq to apply settings
Sep 25 19:38:40 stubby[1626]: Stubby version: Stubby 0.4.0
Sep 25 19:38:40 Samba_Server: daemon is started
Sep 25 19:38:40 custom_script: Running /jffs/scripts/service-event-end (args: start samba)
Sep 25 19:38:40 wsdd2[1645]: starting.
Sep 25 19:38:57 custom_script: Running /jffs/scripts/nat-start
Sep 25 19:38:57 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 25 19:38:57 Skynet: [*] Lock File Detected (start skynetloc=/tmp/mnt/USB/skynet) (pid=1182) - Exiting (cpid=2461)
Sep 25 19:38:58 zcip_client: configured 169.254.193.178
Sep 25 19:39:07 Skynet: [*] WebUI Integration Requires Logging To Be Enabled
Sep 25 19:39:08 Skynet: [#] 188057 IPs (+0) -- 9241 Ranges Banned (+0) || 0 Inbound -- 0 Outbound Connections Blocked! [start] [31s]
