vertigo888
I was wondering if anyone here could help me on the below:
I have the following setup:
I would like to do the following:
Thanks. I did see this post below but don't know if this is still current or if there's an easier way of doing this. There's also no mention of monitoring this either.
https://www.snbforums.com/threads/load-balanced-dual-wan-routing-rules.23381/#post-177774
- RT-AC5300 main Router which is the first device on my network.This has the latest Merlin firmware.
- I have dual WAN in load balance mode
- This hosts various applications which require WAN access.
- This is the main Aimesh router with wireless clients connecting.
- Behind my router are a:
- RP-AC68U which connects my TV, Gaming Console and other devices. Wireless disabled (Re-using this from an older setup I had).
- GT-AC2900 which is configured as an Aimesh node to my main router above. Wireless clients also connect via this node.
- Applications hosted on my main router to go through the primary WAN
- All other devices on wireless or ethernet to go through the secondary WAN
- Monitor both of the above so I can confirm it's working and also monitor traffic long term.
