Dual WAN question
DaveMishSr
I have an Arris SB8200 modem with 2 Ethernet WAN ports. Can I use the load balance in dual WAN to use that 2nd WAN connection? No sense using fail over as if the one fails then both will. Will this give me any benefit?
Also, I am using the 4 LAN ports on my AC3100. Should I use the USB 3.0 port to connect or get a cheap Ethernet hub? Guess I should have sprung for the AC88U.
I'm sorry to pester the forum with this. Having trouble finding info both here and on Asus' support site.
Thanks in advance for any assistance.
Edit: Hoping this is the right forum for this post.
Are they both provisioned? Normally this would incur an extra charge on your account, if it's an option at all.
The Arris website says:
Support for multiple Ethernet ports on a cable modem may require a minimum level of service subscription.
Note, Cox Cable does not support activation of a 2nd Ethernet port.
Thank you. I never thought of checking Arris' site. I should have checked Cox too just to make sure they could support it but I had assumed that they could.
Are you sure they're WAN ports? I thought cable in, ethernet out ... Looking at the image they look like LAN ports, though going by the description they may not be configured to be part of the same segment.
Sent from my MI 5 using Tapatalk
