vertigo888
Hi - Does Skynet support Dual-WAN? I have a Dual WAN setup. If it doesn't, are there plans to support it and with firewall enabled within the Merlin firmware, will the WAN thats's not covered by Skynet be protected?
I have Dual WAN setup due to WAN port failure, with primary WAN set to a LAN port. Router shows secondary as cable unplugged.It's in a load balanced configuration but I have specific clients going down each WAN via rules.
Just to double check here - I have the firmware firewall enabled anyway. This will cover both WAN even with skynet enabled for only 1 of them?
Yes, Skynet only checks wan0_ifname. Just curious what interface(s) are being passed to firewall-start in your system log in LB mode?Is this still true?
I have Dual Wan in Load Balance and Skynet logs only seems to be aware of ppp0 (Primary WAN)
grep "firewall-start" /jffs/syslog.log-1 /jffs/syslog.log
Welcome To SNBForums
