I have a RT-AC3200 running 380.59 Beta 2. I have an Ecobee3 thermostat connected to the router via the 2.4 wireless band. After about 12 hours (rough estimate) of uptime on that band, the router syslog shows a continuous DHCP negotiation process between the Ecobee3 and the router:
May 4 18:20:47 dnsmasq-dhcp[479]: DHCPOFFER(br0) 192.168.64.4 44:61:32:xx:xx:xx
May 4 18:20:48 dnsmasq-dhcp[479]: DHCPREQUEST(br0) 192.168.64.4 44:61:32:xx:xx:xx
May 4 18:20:48 dnsmasq-dhcp[479]: DHCPACK(br0) 192.168.64.4 44:61:32:xx:xx:xx Ecobee
If I disable the 2.4 band and then restart it, the problem goes away but them comes back again approximately 12 hours later.
I only have 3 devices on the 2.4 band. But only the Ecobee3 runs mostly in Powersave Mode according to the Flags on the Wireless Log (and discussions with Ecobee).
This issue was present in the Beta 1 and also 380.58. I've been working with Ecobee to resolve this issue but no luck yet. I'm starting to believe this is something caused by the router/wireless drivers.
Does anyone have any suggestions, or things to try in order to determine what is causing this problem?
Thanks,
MM
Thanks,
MM
